01-12-2012, 09:09 PM | #1 |
Quarry Creeper Join Date: Nov 2010 Location: Sarasota, Florida
| Soldering gone awry.
Well I let one of the guys from Hobby Town solder my leads for my new Tekin FXR and 35T motor together since I'm not good with soldering so i would let the experts do it and when I got home, installed the motor and I realised I had sporadic forward throttle but I got reverse and everything else worked, so I have been tinkering with it and realised that the wires for the motor positive terminal was wired to the negative terminal on the ESC and vice versa for the other wire, but the battery terminals are soldered in right. I was wondering would this mess up screw up my ESC?
01-12-2012, 10:06 PM | #2 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
| Re: Soldering gone awry.
think it would just make your motor run backwards if it was hooked up wrong (opposite of what you have) do you have a hot wire for that ESC?? is it programmed?? did you sync it to your radio after you installed it??? |
01-12-2012, 10:15 PM | #3 | |
| Re: Soldering gone awry. Quote:
I even tried a newer receiver and I had the same problem persist. | |
01-13-2012, 08:35 PM | #4 |
ok, lets get this figured out...what radio do you have?? are all the trims set at 0 and epa's at 100%. When you pull the throttle does it go forward (when it wants to) then push the throttle it goes in reverse? Are all batteries fully charged? You didn't responde to the question of the hot link?? post a pic of your motor with wires soldered on. |
01-13-2012, 09:11 PM | #5 |
Sounds like you need to:
I bet the hotwire isnt recognizing full throttle because it wants what you radio is calling reverse. Also the cutting out may be a couple things, can you describe it better? I'm thinking that you have it on a delayed reverse setting so you have to pull the trigger twice to go forward since if I am right your radio thinks forward is reverse... Last edited by SMR 510RR; 01-13-2012 at 09:13 PM. |
01-13-2012, 10:58 PM | #6 | ||
What I found out (what he said) was that I have to wait one full second before engaging reverse because the ESC waits for the neutral signal before allowing it to accept reverse hence why when I go from forward to reverse immediately I end up pulling the trigger a few times (vice versa when I had my terminal leads on backwards), and he also said that it prevents the motor to mess up the transmission since going immediately from forward to reverse puts some strain on the transmission, that's what the Tekin guy said, so I applied what he said and now it works. I am baffled but it works. I'm now wondering if the Hot wire link will fix this, or what I mean is by improve the time so I'm not waiting a full second. Quote:
2. I will definitely try this out now at some point if the hot link does not fix it, interesting. I thought when you had to solder, the wires had to be in line with the brushes. Hey, thanks guys for some input, I know have some ideas to implement in the future. | ||
01-13-2012, 11:15 PM | #7 |
glad you got it working...canned answer for a shop to tell you that a new radio is in order.....doubtful if its a 2.4..FM, AM yes....sometimes anyway, glad it sorted out. btw, all my Castle ESC's have a delay in reverse..going in full forward then jam it in reverse...it goes in reverse, but after the motor comes to a complete stop...yes, to save tranny. |
01-13-2012, 11:21 PM | #8 |
Here is the manual for the FXR if you dont have a copy: http://www.teamtekin.com/manuals/FXManual.pdf First page lower right tells you how to eliminate the reverse delay, you want the second option "forward to immediate reverse". Turning the endbell of the motor 180 degrees is like soldering the wires to the opposite posts and will reverse motor direction. Last edited by SMR 510RR; 01-13-2012 at 11:26 PM. |
01-14-2012, 09:22 AM | #9 | |
Quarry Creeper Join Date: Oct 2011 Location: Detroit
01-14-2012, 09:50 AM | #10 |
| Re: Soldering gone awry. |
Soldering gone awry. - Similar Threads | ||||
Soldering | landozer18 | Newbie General | 16 | 02-03-2011 01:15 AM |
Burning through soldering tips? And other soldering questions | losikid | Electronics | 14 | 12-16-2010 10:04 AM |
need help soldering.......... | bob1961 | Tools, and Procedures | 9 | 11-27-2008 08:56 AM |
What soldering iron for battery soldering? | Flatty | Electronics | 1 | 06-23-2008 07:35 AM |
Soldering Help Please!!! | tjscrogins99 | Tools, and Procedures | 2 | 12-06-2007 07:32 PM |
