Thread: Best servo for $100?
Old 01-12-2012, 12:11 PM   #1
Default Best servo for $100?
Being a believer in "you get what you pay for", what is the best crawling servo for an AX-10 for no more than $100?
Thanks I'm still running the stock one.
Josh_Br is offline   Reply With Quote
Old 01-12-2012, 12:36 PM   #2
Default Re: Best servo for $100?
Hitec 7954SH and run the bastard @ 9v!
ClassicGMJunkie is offline   Reply With Quote
Old 01-12-2012, 12:45 PM   #3
You can usually get a used Hitec 7955TG for under $100 shipped...that's 333oz/in @ 6.0V. Or a new Hobbico CS170 servo same specs $90 new not including shipping.
alexchen86 is offline   Reply With Quote
Old 01-12-2012, 12:49 PM   #4
USED. I just picked up a used Futaba S9157 for $75.
Classifieds are your best friend my man..
bigstu is offline   Reply With Quote
Old 01-12-2012, 12:57 PM   #5
The hitec 7954 is the best servo for 140 dollars!
And it only costs 80 dollars.
High voltage and over 400 oz on just 6v.
There is no other choice n my book.
holycaveman is offline   Reply With Quote
Old 01-12-2012, 01:10 PM   #6
Thanks guys, this is great info and great options.
Old 01-12-2012, 01:11 PM   #7
+1 7954sh
ftw
Maxx_Savage is offline   Reply With Quote
Old 01-12-2012, 01:56 PM   #8
CS170.... TowerHobbies.com | HCAM0316 Hobbico CS-170 Std Digital Ultra Torq 2BB TG Servo U
7955.... TowerHobbies.com | 37955S Hitec HS-7955TG Digital HT Titanium Gear Coreless Servo
7954.... TowerHobbies.com | 37954S Hitec HS-7954SH High Voltage Ultra Torque Dual BB Servo
7950.... TowerHobbies.com | 37950S Hitec HS-7950TH HV Digital Ultra Torque Coreless TG
S9157.... TowerHobbies.com | S9157 Futaba S9157 Digital High-Torque Servo
I use a 7950 @ 7.4 volts in my 2.2 Bully MOA. There is a shop local to me (that is also on Ebay) that I can get one picked up for ~$120 out the door.
I don't think running any of these long term @ 9vdc would be good.
Charlie-III is offline   Reply With Quote
Old 01-12-2012, 02:15 PM   #9
A question: Is there an advantage to running a High Voltage servo, as opposed to a regular voltage servo? Is anything additional required to run a high voltage servo?
My rig has the stock AX-10 electronics, a CC BEC, and 7.4v / 2s LiPo battery.
Thanks!
Old 01-12-2012, 02:18 PM   #10
the 7954SH will serve well at 9V. you wont stress it that's for sure. as long as you're not running courses back to back to back it gets warm but not hot enough to the touch. i have one in my sportsman and my Xr, both running XR steering over 55*.
Old 01-12-2012, 02:21 PM   #11
Thanks!
servo power and speed will be exponential with more voltage. I had a 7955 TG die from 9V but the high voltage series have loved it.
even throwing nominal battery voltage on 2S to a servo will make you tingle in the naughty bits. at 9v, its really beefcake.
Old 01-12-2012, 02:28 PM   #12
7954 is a good choice 403oz at 7.4v. No idea what benefit you would get from over volting it unless you like buying new servos. The 7950th is a good choice too. 486oz at 7.4v for $114.
https://www.troybuiltmodels.com/items/HS7950TH.html
SINister is offline   Reply With Quote
Old 01-12-2012, 02:50 PM   #13
Got it - that makes sense. * duh *
Old 01-12-2012, 03:13 PM   #14
Does the 50 still have that plastic gear in it?
Old 01-12-2012, 03:15 PM   #15
Never mind, I found it. They all do I guess.
Old 01-12-2012, 07:50 PM   #16
Thanks!
Some people run the servo power direct from the battery, thus they avoid the weak ESC BEC and don't have to buy an external BEC.
The biggest downside to this is that servo power drops off as the battery voltage drops.
Old 01-13-2012, 11:01 AM   #17
Gotcha, thanks!
Old 01-13-2012, 12:30 PM   #18
i have a jr racing z9100t in my creeper thats all metal gear high torque servo and the same specs as the hitec should be 100 to 140 depending on where you find it
89lxmorepower is offline   Reply With Quote
Old 01-14-2012, 12:37 AM   #19
just bought a hitec HS 7955TG servo for 119.99 plus tax came out to 134.00.. my friends have the same servo and have ours plugged into the receiver and we're not running a BEC and havent had any problems. we are running 2s 800-850mah lipo's.
AX10wannabe is offline   Reply With Quote
Best servo for $100? - Similar Threads
Crawler Innovations Servo Guard - Servo Clamp - Servo Mount GIVEAWAY!!! Nova's Ark General Crawlers 219 10-18-2010 12:43 PM
Whose quote is give 100 people a chassis and they'll build it 100 diff ways? Rig Rocker Chit Chat 6 10-05-2010 10:40 AM
looking for good servo under 100$ Axialfan19 Electronics 20 09-10-2010 09:48 PM
