01-14-2012, 06:00 AM | #1 |
Pebble Pounder Join Date: Oct 2011 Location: Kansas City, MO
| Find me a charger! 100 bucks or less, 20 amp charging rate- power supply included
No, don't go out of your way, but if you know of a good charger that fits that description, please post it up. I currently have a Thunder T610 that I purchased *ahem* under the influence, and have discovered upon receiving it that it doesn't include a power supply and it only charges at a max of 10 amps. I'd like to be able to charge 5-6000mah packs at 2-3C. EDIT: I could live with an external supply, I just don't want to spend much more than 100 bucks on one to get the job done. I don't fancy the idea of spending an hour and a half waiting for packs to charge. Last edited by Zeus.:God; 01-14-2012 at 08:07 AM. |
01-14-2012, 09:52 AM | #2 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
| Re: Find me a charger! 100 bucks or less, 20 amp charging rate- power supply included
search a little bit around here...and might find something
01-14-2012, 12:15 PM | #3 |
| Re: Find me a charger! 100 bucks or less, 20 amp charging rate- power supply included I have, and I haven't found much of anything; some talk about chargers that won't do what I'm looking for, and that's about it. But since you say it like you know there is something, why not post the link (kinda' the reason I made the thread)? I always search first. EDIT: Better yet, can you answer me this? I have a 5300mah battery, and I'd *like* to charge it at 2C- obviously I can't do that with my current charger, as I would be .6a off. Would I be OK to charge it at 10a rather than 10.6a? Does the charging rate have to be exactly 1, 2, 3x the mah or can I pretty much charge at whatever amperage I like, no worries? Last edited by Zeus.:God; 01-14-2012 at 12:26 PM. |
01-14-2012, 12:51 PM | #4 |
Quarry Creeper Join Date: Jan 2010 Location: USA
You should have no problem maxing out your charger at 10A. It doesn't need to be and exact C number. This would be more like 1.9C (for your 5300mah battery) and would get the job done in 32 minutes instead of 30 minutes. Just make sure your battery is rated to be charged at that high of a rate (some are limited to 1C, other can be higher).
01-14-2012, 01:03 PM | #5 |
The battery is a Gens Ace 2S 5300mah and I read that they're rated up to 5C (a bit generous in my opinion). I've read about people charging these at ~15-20 amps so I figured 2C should be fine. And are you sure it doesn't need to be an exact C number? I'd like to know for sure before I bother buying the power supply for this charger (kinda' giving up on buying another one- not wise with the budget).
01-14-2012, 01:12 PM | #6 |
Quarry Creeper Join Date: Nov 2011 Location: Cookeville
You know i would suggest some charges but tbh with a title like this im suprised anyone would help. If you want help dont demand it in the title. Just my opinion so Gl to you.
01-14-2012, 01:43 PM | #7 |
^^^^^^^^^^ reason why I requested the search
01-14-2012, 02:05 PM | #8 | |
| Re: Find me a charger! 100 bucks or less, 20 amp charging rate- power supply included Quote:
Do either of you have worthwhile suggestions or are we going to focus on something other than the subject at hand? | |
01-14-2012, 02:15 PM | #9 |
Pebble Pounder Join Date: Mar 2010 Location: PHX
| Re: Find me a charger! 100 bucks or less, 20 amp charging rate- power supply included |
01-14-2012, 02:22 PM | #10 |
01-14-2012, 03:25 PM | #11 |
Hobbypartz sells a 25 amp power supply.
01-14-2012, 04:02 PM | #12 | |
For most packs, charging at "1C" means the pack is fully charged in 1 hour. If you are balancing, it may take a lot longer (depends on your pack). I didn't answer your 1st post based on the perceived "demand" in the thread title. Rather than flame, I decided to wait to see what transpired later in the thread. Just saying. | |
01-14-2012, 04:21 PM | #13 |
RCC Addict Join Date: Oct 2009 Location: Nanaimo, BC (Vancouver Island)
here is your cheap power supply option, Modding a PC Power Supply into a 12 Volt Supply for your DC charger I just did this with a power supply I got for free that has 22amps on the 12v rail. These can be had out of an old pc that usually get left at the dump or recyclers for free. This should get you right in the ball park of what you want in a charger http://www.hobbypartz.com/75p-1220-charger.html Now, I demand a thank you |
01-14-2012, 04:44 PM | #14 | |
AAANNNNDDD I had the similar question a long time ago, I just did my own searches, then asked the question if these were worth a crap, listed my findings....did I say ask....I did.... soo again, best wishes to you | |
01-14-2012, 09:20 PM | #15 | |||
Which is why I came here and asked. If someone KNOWS of a good charger, that means they've probably owned or used it, or at least heard good things about it. Public opinion is what I'm searching for now, and this subject isn't exactly well documented. Quote:
But thank you, for actually sticking to the topic. Appreciated. | |||
01-14-2012, 09:45 PM | #16 | |
I honestly would never, ever attempt to pump anywhere close to that much juice into a a battery while charging in or near my house | |
01-15-2012, 01:51 AM | #17 | |
As for the high charge rate, as I understood it, my battery is advertised as being capable of 5C charge rates and that they had to be charged exactly. 1C = roughly 1 hour 30 minutes at 5.3a, 2C = about, if not a little more than, half that at 11.6a. My thought was to charge it at 2-3C so that my charge times do not exceed run time, which would require 11.6a or 15.9a, and I've read about people charging as high as 20 amps on various batteries without issues. I have a firebag and a safe place in which to do my initial charges, but it looks like i won't be going to such "extremes" as I was initially planning, so I'm not too worried (as if I were in the first place). Last edited by Zeus.:God; 01-15-2012 at 03:39 AM. | |
01-15-2012, 06:32 AM | #18 |
Other than balancing (and getting the currect balance plugs) LiPO is really not much different that NiCD & NiMH. -You don't want to over discharge -You don't want to overcharge -You shouldn't just "walk away" from packs while on charge -Be mindful of where you're charging, "just in case" -Don't short the batteries -When charging, you can do high charge rates, but the packs last longer with low charge rates -While we may not have called it "1C", that is what a lot of us did -Unless you were using a "timer charger" (ewwww......) we had peak detecting chargers, adjustable for cell count & amps, etc While I can understand not wanting to wait for packs, I just have multiple packs, charge the day before & top off just before use. Good luck in your search. |
01-15-2012, 07:30 AM | #19 | |
I only have one pack right now, considering purchasing another to charge while I'm running, but with all of my hobbies, work, and girlfriend, I'm not going to be planning ahead, it'll be as the opportunity arises. Anyway, I suppose this thread has served it's purpose. I've already purchased a power supply for the charger I have. Thanks for the advice. | |
01-15-2012, 07:35 AM | #20 | |
You could always leave most of a charge in a pack so the time to top it off is short. Having 2 packs at a minimum is good in case one decides to die, you're not left "dead in the rocks" as it were. Good luck. PS, what did you end up getting? | |
Find me a charger! 100 bucks or less, 20 amp charging rate- power supply included - Similar Threads | ||||
Modding a PC Power Supply into a 12 Volt Supply for your DC charger | TwistedXT | Electronics | 166 | 05-22-2019 07:28 PM |
Using a computer power supply to power up my charger.... | AYKBOBCAT | Electronics | 15 | 03-30-2005 07:41 PM |
