Thread: switch setup for rear steer and winch servo
Old 01-16-2012, 08:17 PM   #1
Default switch setup for rear steer and winch servo
Ok So I was curious if this would work for what I want. I want to keep power going to my rear steer servo while I use the winch and vice versa. So I was curious if i put a switch pictured above on the white wire and keep the power and ground attached directly to the separate servos that way they stay on and my rear steer stays put while using the winch. I hope what I'm saying makes sense. Please give me your input and help if you can. Thanks.
jthellfire911 is offline   Reply With Quote
Old 01-16-2012, 10:17 PM   #2
Default Re: switch setup for rear steer and winch servo
I've played with this sort of arrangement. It often works, but it depends on how the servo behaves when power is removed. If I recall, some will try and hold their last position, some go limp.
heyok is offline   Reply With Quote
Old 01-16-2012, 10:58 PM   #3
I'm running savox servo in the front and soon to have one in the rear. "stock axial wraith front servo for rear steer"
I was planning on possibly going through you for a controller for my servo winch. If this is a cheap way to go for now till I can get a 4ch radio I'll do it. Not like it will cost alot to do. LOL.
Old 01-17-2012, 06:53 AM   #4
Thanks! I'll make sure I have a winch controller here for you!
Old 01-17-2012, 08:30 AM   #5
Make sure your failsafe posistion is set to straight ahead for the rear steer and nuetral for the winch.When you switch the signal off the servo should go into failsafe mode.
hotwheels000 is offline   Reply With Quote
Old 01-17-2012, 09:38 AM   #6
I always thought Failsafe was a feature of the receiver. Does that also apply to some servos?
Old 01-17-2012, 03:08 PM   #7
That is actually where I was refering to.
It is a feature on some rx/tx,not all radios have this. Even the ones that do, dont always have a failsafe on every channel.
With a hitec servo programmer it can be done thru the servo also.
switch setup for rear steer and winch servo - Similar Threads
DX3R Pro rear steer setup Low F350 Electronics 2 04-29-2011 07:25 PM
JR Z-1 rear steer setup help. mysterrik Axial AX-10 Scorpion 4 02-02-2009 08:58 PM
Rear steer with wheel instead of switch? MNorby Electronics 4 06-09-2008 01:01 AM
How to setup indy rear steer on dx3 azDcab05 Electronics 2 05-12-2007 12:30 PM
a switch for rear steer! nd4spdbh Electronics 13 07-27-2005 09:54 AM
