01-15-2012, 04:42 PM | #1 |
Newbie Join Date: Dec 2011 Location: Canada
| LIPO battery issues
Hey I have an 7.4 volt 5000mah 25c onyx lipo battery and I have an onyx 235 charger. I can't charge it cause I'm scared I havent set it up right u have read all instructions but last lipo I had blew up and almost burned down my house, I had everything set up right to can someone tell me how to set it up so it will charge good and have a long battery life?
01-15-2012, 04:47 PM | #2 |
Also it says to have the output voltage set at no higher than 4.2 bolts per cell but I can't change that in the onyx 235 and it says input voltage is 12.73 volts I can't figure out how to change it.
01-15-2012, 04:52 PM | #3 |
| Re: LIPO battery issues
Input voltage is what goes INTO the charger, has nothing to do with what goes INTO the battery pack. To charge a pack, set to chemistry (LiPO), cell count (2S), charge rate (1C is normal, 5amps for a 5000mah pack = 1C) plug it in & let her rip. If in doubt, put the pack in a LiPO sack, large coffee can, back porch on cement, driveway, etc. before charging. Then, "if something happens" nothing but the pack will burn. |
01-15-2012, 04:56 PM | #4 |
Ok thanks but how do I change my output voltage ??
01-15-2012, 05:01 PM | #5 |
When you set it for 2s it sets the output voltage to 8.4v (4.2 per cell). Punch in 5000 for the capacity and it'll set to 5 amps (1c).
01-15-2012, 05:07 PM | #6 |
Ok thanks so it should be ready for charging once I do that also I am wondering if you can tell me how to properly discharge the battery
01-15-2012, 05:09 PM | #7 |
| Re: LIPO battery issues |
01-15-2012, 05:10 PM | #8 |
But the battery is only 7.4 volts isn't 8.4 volts to high?
01-15-2012, 05:11 PM | #9 |
01-15-2012, 05:35 PM | #10 |
Ok so it is charging now and its output voltage is 8.04 volts
01-15-2012, 05:59 PM | #11 |
It says it's done but it only charged 1864 mahs out of 5000 could it be partially charged out of the box??
01-15-2012, 06:12 PM | #12 |
Ya, they come with some charge in them. Just make sure the LVC is on on your ESC and run it.
01-15-2012, 11:00 PM | #13 |
Ok thanks I'm running this in my LCC and can't get any torque I have a 12 tooth pinion and 45 turn motor I have tried 18 tooth and 27 turn motor but nothing works
01-16-2012, 06:26 AM | #14 | |
| Re: LIPO battery issues Quote:
If you had issue with the 12tooth pinion on the 45T motor, then changed to a 18tooth pinion with a 27T motor you went the wrong way on BOTH. The 27T motor is a bit hot (fast) for a crawler. Are these new motors or old? What battery connectors? You may want to look in the LCC forum to see what they recommend for motors & gearing. Additionally, IIRC, the LCC is a worm drive axle, they tend to eat brushed motors very fast. Most recommend to run a brushless system. If you've run both these motors for some time in the LCC, you may have used them up. | |
01-16-2012, 06:29 AM | #15 | |
How long did the charger run? I know when I balance some of my packs I hit the 120 minute time limit & have to restart the charge to get to the voltage limit. | |
01-16-2012, 06:48 AM | #16 | |
Newbie Join Date: Nov 2011 Location: Metropolis
Thanks Don | |
01-16-2012, 07:00 AM | #17 | |
RCC Addict Join Date: Dec 2010 Location: middle,tn
J-bird | |
01-16-2012, 07:13 AM | #18 |
| Re: LIPO battery issues Thanks J, i bought a thunder ac6 balance charger should be able to do that np. UPDATE my charger still gives me the same error message LOW VOLTAGE, and will not charge this battery , what kind of charger do you have J ?
01-16-2012, 07:35 AM | #19 | |
You "may" bring it back, but it's life may also have been shortened. PS, I'm fine, thanks for asking. | |
01-16-2012, 07:43 AM | #20 |
Ok thanks Charlie i will try that right now . UPDATE it appears to working ,i have it set at 3a charge rate , is this a charge rate you reccomend or should i do this slower at a lower rate ? 2ND UPDATE Fixed and it`s now taking a balance charge on the lipo setting ,Thanks for the help guys !!! Last edited by Rock_Diggn_Don; 01-16-2012 at 07:58 AM. |
LIPO battery issues - Similar Threads | ||||
lipo issues! | SCX-KRAWLER | Electronics | 3 | 06-24-2011 11:13 PM |
LiPo Issues | megaherz | Electronics | 6 | 04-04-2011 11:54 AM |
What Zippy Lipo battery fits a Crawler King? Or whats your favorite 2c lipo battery? | phunkodelic | HPI Wheely King | 20 | 08-31-2009 01:35 PM |
battery issues... | 85toycrawler | Axial AX-10 Scorpion | 20 | 07-26-2008 11:30 PM |
