01-31-2012, 10:54 AM | #1 |
Pebble Pounder Join Date: Nov 2009 Location: pennsylvania
| scx10 is spazin
alright so I'm running a futuba esc, mrp motor and traxxes servo and the thing goes nuts, the motor will throttle up when it should the tires will twitch ad then its fine? where should I start? maybe reciever? esc? thanks makes it tough to crawl when it wants to tweak out |
01-31-2012, 11:14 AM | #2 |
| Re: scx10 is spazin
Is this a "new to you" rig?, if not, did this just start happening? Did you try calibrating the ESC to the RX? Did you try a different battery? Brushed motor or brushless? If it's older, have you done any service to the motor? Sorta sounds like worn brushes that need to be replaced. |
01-31-2012, 11:31 AM | #3 |
| Re: scx10 is spazin
built the dingo myself. the esc was out of a old truck, motor was older but never used in packaging lol.
01-31-2012, 04:46 PM | #4 |
| Re: scx10 is spazin
lose connection too the receiver... thanks for the help!
scx10 is spazin - Similar Threads | ||||
T.O.M's SCX10 - The True Power of Axials SCX10 | stewbaru | Axial SCX-10 | 4 | 08-17-2011 07:30 PM |
scx10 rtr vs. scx10 kit | newblnc | Axial SCX-10 | 15 | 02-19-2011 08:19 PM |
Will SCX10 Honcho Kit Parts Fit on Older SCX10? | alexchen86 | 1.9 Scale Rigs | 4 | 12-23-2009 03:56 PM |
