02-10-2012, 08:00 PM | #1 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
| 3R question?
I have had my 3R for 3+ years now and it has been a great radio. One problem I do have with it is when I try to assign a servo or a winch to the 3 position switch, I usually have to go to a unassigned Model # to get it to accept the servo or winch. I have followed what the manual says to do to assign it, have even tried to re-bind with no luck. Anyone have this problem and if so what Iam I doing wrong. Thanks for any info on this problem.
02-10-2012, 10:50 PM | #2 |
| Re: 3R question?
Should be as simple as changing one of the switches to a 3 postion switch or linear depending on what you want. What part of the process isnt working? Have you checked the monitor screen to see if the radio is properly configured? |
02-11-2012, 07:00 AM | #3 |
| Re: 3R question? Well if Iam reading the manual correctly, you choose what function you want the switch to perform. I my case it is the AUX 3 postion switch. I go the the Switch set-up screen and choose and high-lite that switch then with the "box" that high-lites it choose that switch. (Can you tell I dont have very good electronic skills). Iam sure I am missing something in the process.
3R question? - Similar Threads | ||||
Drive way too fast question and front locker question. | Mr.JayDeeM | Axial AX-10 Scorpion | 15 | 02-07-2012 09:19 AM |
clearance question and articulation question | axialnut | Newbie General | 17 | 09-24-2010 09:55 PM |
Simplefied question for pervious question. | Mudsy | Tamiya Clod Buster | 2 | 05-03-2009 09:59 AM |
