02-17-2012, 03:01 AM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: middlesbrough, uk
| what's wrong with my motor?
turned scx10 on properly and immediately rooster esc went into thermal shut protection and battery (6cell nimh) burnt out, I disconnected battery and the truck is stiff as hell on its drive train where its normally nice and smooth. any help at all? I think its a motor issue but I'm clueless... motor isn't turning at all.
02-17-2012, 06:49 AM | #2 |
| Re: what's wrong with my motor?
Loosen the motor mount screws and slide it away from the spur. Turn the wheels by hand and see if there is still binding. If the binding is not present, then you have a problem with the motor. It might be anything from simply needing a rebuild to something lodged in the motor itself. |
02-17-2012, 07:23 AM | #3 | |
| Re: what's wrong with my motor? Quote:
- That would be a short circuit in the ESC, on the "input" side. - It should not affect the drive train! If you did try to make the car run before it got hot, then I'd guess it's a short in the motor, possibly (at worst) welding the motor axle down. | |
02-19-2012, 03:23 AM | #4 |
right so i tried touching the moor to the turned off esc to find the motor spin at high speed, i have a short in my esc, when i turn it on, it smells. if this happens with you, buy a new esc.
what's wrong with my motor? - Similar Threads | ||||
what i'm i doing wrong, motor keeps giving out. | TRAV | Electronics | 8 | 05-17-2011 11:54 AM |
Not sure what I am am doing wrong. | Jslick | Team Losi Comp Crawler | 6 | 01-08-2011 01:27 PM |
Wrong Motor | TheGerman | Electronics | 2 | 06-08-2008 02:33 AM |
Whats wrong with my motor?? Please help! | andres-tavares | Newbie General | 5 | 01-24-2008 07:43 PM |
Motor on wrong side for all laydowns. | oIIIIIo | Tamiya TLT Crawlers | 11 | 03-26-2006 09:07 PM |
