Thread: what's wrong with my motor?
Old 02-17-2012, 03:01 AM   #1
Default what's wrong with my motor?
turned scx10 on properly and immediately rooster esc went into thermal shut protection and battery (6cell nimh) burnt out, I disconnected battery and the truck is stiff as hell on its drive train where its normally nice and smooth. any help at all? I think its a motor issue but I'm clueless... motor isn't turning at all.
lordjasper1988 is offline   Reply With Quote
Old 02-17-2012, 06:49 AM   #2
Default Re: what's wrong with my motor?
Loosen the motor mount screws and slide it away from the spur. Turn the wheels by hand and see if there is still binding.
If the binding is not present, then you have a problem with the motor. It might be anything from simply needing a rebuild to something lodged in the motor itself.
JeremyH is offline   Reply With Quote
Old 02-17-2012, 07:23 AM   #3
Originally Posted by lordjasper1988 View Post
turned scx10 on properly and immediately rooster esc went into thermal shut protection ...
You didn't even touch the throttle before this happened?
- That would be a short circuit in the ESC, on the "input" side.
- It should not affect the drive train!
If you did try to make the car run before it got hot, then I'd guess it's a short in the motor, possibly (at worst) welding the motor axle down.
Olle P is offline   Reply With Quote
Old 02-19-2012, 03:23 AM   #4
right so i tried touching the moor to the turned off esc to find the motor spin at high speed, i have a short in my esc, when i turn it on, it smells. if this happens with you, buy a new esc.
what's wrong with my motor? - Similar Threads
what i'm i doing wrong, motor keeps giving out. TRAV Electronics 8 05-17-2011 11:54 AM
Not sure what I am am doing wrong. Jslick Team Losi Comp Crawler 6 01-08-2011 01:27 PM
Wrong Motor TheGerman Electronics 2 06-08-2008 02:33 AM
Whats wrong with my motor?? Please help! andres-tavares Newbie General 5 01-24-2008 07:43 PM
Motor on wrong side for all laydowns. oIIIIIo Tamiya TLT Crawlers 11 03-26-2006 09:07 PM
