03-07-2012, 09:39 PM | #1 |
Newbie Join Date: Apr 2006 Location: Collinsville
| I think I need new electronics
This what I have for my AX-10 Scorpion(don't laugh). Integy V10 Matrix Rock Crawler Professional Motor 55T Futaba S3003 Servo Standard Futaba R152JE 2-Channel AM Receiver 75MHz Futaba 2PH 2-Channel AM Tazer 15T Forward/Reverse ESC 1500 NiMH Split 6 Cell Battery Dynamite Mega 1 Quick Charger My ESC has died and I have to have a new one. I would like to upgrade all of what I have but do not have the cash to do so. Any help or point in the right direction would be great. |
03-07-2012, 10:03 PM | #2 | |
Gold Star Baby! Join Date: Jan 2011 Location: SOUTH JORDAN, UT
| Re: I think I need new electronics Quote:
03-07-2012, 10:33 PM | #3 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver, WA
here is what i would get for an inexpensive setup: Sidewinder ESC 35T motor (don't skimp if you don't have to) castle 10A BEC hitec 645mg servo FS-GT3B 2.4ghz transmitter from hobbypartz cheap lipos from hobbypartz or value hobby thunder AC6 charger |
03-08-2012, 12:45 AM | #4 |
| Re: I think I need new electronics So, what's the objective with the upgrade? - You have a nice motor for slow crawling. Do you want more speed, torque or both? - The radio should be working as is. - New ESC, of course. (I don't know ESCs well enough to guide you here, but the new ESC should have drag brake function.) - Your servo I don't know. Do you experience any problems with it? - A 2S LiPo battery will give you reduced weight and a little more speed and power with everything else the same. LiPo batteries will require a new charger. So, with a new ESC being the first step, I'd recommend a battery (and charger) replacement as the second step. From there your (to me unknown) desires should set the priorities. |
03-08-2012, 06:09 AM | #5 |
Rock Crawler Join Date: Mar 2011 Location: hampton
your motor is decent. esc, i run losi msc12L esc,s in 3 of the 4 trucks i got. good esc, has LVC and crawler mode with a good drag brake. in the ball park of $35 used. the s3003 servo is way to weak, and the gears wont last long. if your just rippin and runnin around the yard look at the solar or EXI servos from hobbyparts.com. you can also get your lipos,charger and a BEC from them too your radio, though am is not great,its been around for many years and they still work. I would go in this order get a esc first to get the truck up and running. then go servo and BEC. you'll need a JR servo horn for solar or exi servos then lipos and charger radio last Last edited by stanmondz; 03-08-2012 at 06:11 AM. |
03-08-2012, 01:32 PM | #6 | |||
| Re: I think I need new electronics That's not nice.........but it would be cool. Quote:
I think I need new electronics - Similar Threads | ||||
lowering the body and the electronics getting the electronics in a waterproof box | m1009cucv | Axial SCX-10 | 15 | 10-01-2011 07:45 PM |
Need some electronics | ziz | General Crawlers | 0 | 03-12-2008 07:34 PM |
HELP!!! I need you help with electronics | 007KRAWLER | Electronics | 7 | 11-03-2006 10:56 AM |
electronics | chimney | Electronics | 4 | 10-05-2006 02:23 PM |
