03-20-2012, 05:42 AM | #1 |
Rock Crawler Join Date: Mar 2011 Location: hampton
| testing a waterprrof box with electrics in it
im using a servo box to put all my electrics in, once i seal it up,can i submerge it with NO POWER hooked up to make sure its sealed completely. and my electrics live if it does have a leak? im gonna seal it up with shoe goo, i don't want the house to smell like silicone for a week |
03-20-2012, 07:25 AM | #2 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
| Re: testing a waterprrof box with electrics in it
you can, but you shouldn't... use extension wires to go through the box so that #1, you can test it without electronics in it, and #2, you can easily change components when necessary.
03-20-2012, 10:21 AM | #3 |
thought about that, but then id have to cut it open and mount the electronics, then seal it up again. which would put me in the same boat. i painted everything with liquid tape also, so should be ok if i end up with a leak
03-20-2012, 01:36 PM | #4 |
maybe mount the electronics to the top so if there is a leak it wont get to them as easily..
03-20-2012, 09:10 PM | #5 |
it failed twice. guess ill try the next suggestion in the waterproofing thread
03-21-2012, 08:40 AM | #6 | |
| Re: testing a waterprrof box with electrics in it Quote:
2pcs New Waterproof Plastic Project Box Electronic Case DIY 83 x 58 x 34mm | eBay that's what i bought, although i have not received it yet, but it should be an OK size based on my guesstimates. | |
03-21-2012, 03:05 PM | #7 |
didnt know those existed. thanks man
03-22-2012, 08:44 AM | #8 | |
Newbie Join Date: Feb 2012 Location: OP
03-22-2012, 05:55 PM | #9 |
I will do that... there are some that are a bit bigger too, but my ESC is waterproof so i only need to put my RC and BEC in here i just did some quick measuring on my hitec servo box, and it's 93x78x34... so depth is the same, the ebay box is 1cm (~3/8") shorter on length and width... just to give you a bit of an idea, should easily fit a receiver and small esc like an fxr, as well as a bec. Last edited by T3rry; 03-22-2012 at 06:00 PM. |
03-24-2012, 01:48 AM | #10 |
RCC Addict Join Date: Jan 2007 Location: San Jose
Any word yet? I am really curious about this too. Thanks for doing the work to find this out for us.
testing a waterprrof box with electrics in it - Similar Threads | ||||
where are your electrics? | crazee horse | Axial Wraith | 8 | 12-11-2011 01:34 AM |
Best electrics for CR 01 | Motorhead | Tamiya CR-01 | 2 | 03-20-2010 05:46 PM |
what electrics for kit? | stampedecrawler | Axial SCX-10 | 0 | 12-24-2009 09:50 PM |
electrics box | dezl_dub | Newbie General | 3 | 11-29-2009 09:08 PM |
No Electrics | cpower36 | HPI Wheely King | 1 | 02-22-2008 03:10 PM |
