Thread: 1998 novak rooster......?
Old 04-06-2012, 04:31 PM   #1
Default 1998 novak rooster......?
Hi guys. I got a wheely king that had a burnt esc in it. I have a old school novak reversible rooster. 2 questions......#1 will this old rooster work with the wheely king pieces......and #2 would the rooster be ok running on 8.4 volt venom racing 7 cells?
M0D3RN C0WB0Y is offline   Reply With Quote
Old 04-06-2012, 05:29 PM   #2
Default Re: 1998 novak rooster......?
it should work fine as long as the motor is higher than a 12t
benoj is offline   Reply With Quote
Old 04-06-2012, 07:58 PM   #3
Ya i have no idea. The motor is a stock wheely king motor. i just dont want to burn up the rooster esc with the 8.4 volt batteries.
Old 04-06-2012, 08:02 PM   #4
ok so the wheely king comes with a 540 27t motor? So my rooster would b good in it with a 8.4 volt battery.
Old 04-06-2012, 08:22 PM   #5
There was a time when the old Roosters were as common in Crawlers as Tekin FX-R's are now.
I think you'll be ok; it's rated at 6 to 7 cells with a motor limit of 15T on 6 cell, so a 27T on 7 should be fine.
Here's the spec page in case you don't have your paperwork:
Specs: Reversible ESCs
CreepyCrawl is offline   Reply With Quote
Old 04-06-2012, 08:35 PM   #6
Ok ill try it out, i gotta figure out how to hook up the 2 wires to the motor, as they arenot color coded.
Old 04-06-2012, 08:44 PM   #7
Should be Blue (negative) and Yellow (positive) to the motor, Red (positive) and Black (negative) to the battery.
Old 04-06-2012, 08:57 PM   #8
The guy I got it from rewired it, and the wires coming off the motor are the same damn color......sory im a noob.
Old 04-06-2012, 10:12 PM   #9
Well, assuming that the previous owner replaced the wires correctly, you should be able to use a stock image of the Rooster to follow which is which as they exit the housing and get your wiring correct.
Once you figure it out, use some Red heat shrink to identify the positive leads for future reference.
Old 04-06-2012, 11:50 PM   #10
Ya im having trouble finding a diagram for the rooster.
Old 04-07-2012, 08:27 AM   #11
Don't worry about the motor wire colors, if you do it backwards, the motor will run reversed, so just swap them. You won't hurt anything.
Getting the input wiring (pack to ESC) backwards WILL fry the ESC.
Charlie-III is offline   Reply With Quote
Old 04-07-2012, 08:30 PM   #12
Ok i got it wired up and i turn on the power,and the servos work. But dont i still have to program it to the motor? idk what im doing lol....its got one led light and one littler button.....how do i set this thing up?
Old 04-07-2012, 11:05 PM   #13
it should be like the others with one touch setup where you press the button till i believe it turns red hold full forward and the full reverse then back to not throttle and should be good to go but regardless heres a link to download page for their escs, the closest one if you scroll down to brushed is the rooster 12t
Instruction Manuals
1998 novak rooster......? - Similar Threads
novak super rooster+novak 2s smart stop problem..help infamouse_1 Electronics 1 04-23-2009 08:18 AM
Tekin Rebel 2/novak Rooster Crawler/novak Super Rooster? CHRIZAD Electronics 7 09-15-2008 07:22 PM
momba max vs. novak goat vs. novak rooster crawler punkafi888 Electronics 4 01-20-2008 02:05 AM
