04-22-2012, 10:07 AM | #1 |
Newbie Join Date: Mar 2012 Location: marshall
| Need major help
Ok I have a clod rig I purchased a few months ago and I can't seem to get this thing to work properly. It's running stock Tamiya cans MOA, Traxxas 2.4 tx/rx, traxxas EVX-2 and dual 7cell Nimhd. Here's the problem, it either runs full blast forward or full blast reverse. There is no feathering the throttle (JUST GO!).........................WTF
04-22-2012, 10:09 AM | #2 |
| Re: Need major help
Also I have tried switching between sport, racing and training modes. No change
04-22-2012, 10:33 AM | #3 |
| Re: Need major help
Here is the manual.... http://traxxas.com/sites/default/fil...ons-2008_0.pdf Did you set-up the TX 1st (per the manual) and then calibrate the ESC to the RX? I'm assuming you did, but need to ask anyway. |
04-22-2012, 10:55 AM | #4 |
| Re: Need major help
Calibrate your ESC first, see if that fixes it. If you put a different radio (tx&rx) on it and it works right, then your current radio has too much expo dialed into the throttle channel. Not sure that radio has that capability, though. If you put a different ESC on your current radio and it works fine, then it's an ESC issue, probably need to send it in to find out if you've lost all your low speed FETs. If it winds up being a burned up ESC, when you get it back, lower your gearing, or you'll likely be right back in the same situation again soon. |
04-22-2012, 03:20 PM | #5 |
| Re: Need major help
Ok guys, that fixed it. I thought I had already calibrated but apparently I was wrong.............lol
04-22-2012, 04:53 PM | #6 |
| Re: Need major help |
Need major help - Similar Threads | ||||
Major newbie, i do mean new | lifebeginsafterdeath | Newbie General | 19 | 04-29-2011 02:10 PM |
major glitching | yukonite420 | Electronics | 10 | 11-04-2009 03:38 PM |
major glitching | CrawlnYota33 | Newbie General | 9 | 09-25-2007 08:19 PM |
a little here....some there....nothing major | muddeprived | General Crawlers | 5 | 05-24-2006 03:19 AM |
Major problem | MaxxZilla | General Crawlers | 23 | 05-27-2004 11:59 AM |
