04-22-2012, 10:09 AM | #1 |
Quarry Creeper Join Date: Aug 2009 Location: here
| Quick mod for a CC BEC
What I did to make my BEC a little more compact. Cut the shrink wrap off and you have something like this, I shortened the RX wires before the pic Remove the brown plastic piece on top, just pull it straight off. Get some micro deans, I like polarized deans and only had regular so I pulled a pin from each half and swapped them to make polarized deans Solder some leads to one side and cut the grip tabs off the sides, I only cut one off at first but later had to cut the second one off Using adhesive of your choice glue the micro deans to the BEC. I used clear RTV silicone After your adhesive dries solder your leads to the BEC and slide some heat shrink over the entire BEC Then glue it on where ever you want it mounted at |
Quick mod for a CC BEC - Similar Threads | ||||
BEC electronics: simple mod? | Oseetoo | Electronics | 1 | 04-12-2010 02:14 PM |
Need quick BEC help! | MCNorris | Axial AX-10 Scorpion | 4 | 03-21-2009 04:32 PM |
Quick BEC ?? | slickwillie | Electronics | 5 | 07-08-2008 12:08 PM |
a quick question about the CC BEC | Mac10 | Electronics | 5 | 04-02-2008 01:09 PM |
