04-29-2012, 10:29 PM | #1 |
Rock Crawler Join Date: Oct 2011 Location: minot
| MMP bec?
ive got a MMP and a hitec 7955tg servo.. planning on 3s as a power source do i need to run an external bec with the MMP on my wraith? ive also heard of directly wiring the servo to the battery... with 3s is this a bad idea (over volting?) is the only wire conneting to the rx the white signal wire at that point? would i still need to run a bec to regulate voltages? |
04-29-2012, 10:43 PM | #2 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Re: MMP bec?
No, you should be fine. I have never ran a BEC on anything. If you were to search BEC you would find 1000's of people all saying a BEC is needed but they are wrong. My friends cousins brother's friend has a redcat with 17 servos and he never uses a BEC, so that is as good as gospel to me.
04-29-2012, 10:45 PM | #3 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: MMP bec?
Answer to the first question....YES....I run the same servo and MMpro w/13.5 brushless..3s....needs an external BEC I don't have an answer for the second question....but wonder why you would do that. |
04-29-2012, 10:47 PM | #4 |
| Re: MMP bec? You don't NEED to do anything, but it would be better to run a bec for a myriad of reasons. Searching helps... |
04-29-2012, 10:48 PM | #5 | |
| Re: MMP bec? Quote:
04-29-2012, 11:38 PM | #6 | |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: MMP bec? Quote:
04-30-2012, 07:20 AM | #7 |
| Re: MMP bec?
guessing the common idea is to run the external bec...
04-30-2012, 09:17 AM | #8 | |||
| Re: MMP bec? Sadly, no. The most common idea seems to be coming on here whining about "my truck stalls when I try and turn the wheel and hit the throttle", and then trash talking 'faulty/junk equipment'. Quote:
MMP bec? - Similar Threads | ||||
MMP and external BEC? | TSK | Electronics | 5 | 03-11-2011 08:54 PM |
