05-01-2012, 10:45 PM | #1 |
Newbie Join Date: Feb 2012 Location: Eatonville
| steering glitch
Building a wraith kit with my son. Put battery in front(3s). Spektrum TX/rx. Tekin fxr, castle bec set to 7.2, wired direct to servo, only signal wire to rx. Every time we punch the throttle the wheels turn, they straighten out as you drive, but even when you're moving, punch it and the wheels turn. Any ideas?
05-01-2012, 10:57 PM | #2 |
| Re: steering glitch
Spektrum radios have been known to glitch without a ground wire going from the servo to the rx. That would be the first thing I would try.
05-01-2012, 11:14 PM | #3 |
| Re: steering glitch
So can I share the ground with the bec?
05-02-2012, 04:47 AM | #4 |
| Re: steering glitch Spektrum radios like the servo ground to the RX to reduce glitching. Right now, you have 2 servo wires going to the BEC & 1 servo wire to the RX (signal). You either need to move the servo ground (black or brown wire) to the RX or make a jumper so the servo ground goes to the RX & BEC. |
05-02-2012, 06:54 AM | #5 |
| Re: steering glitch
Made the ground go to both, works great, thanks!
06-08-2012, 11:26 PM | #6 |
Newbie Join Date: Dec 2009 Location: Santee
| Re: steering glitch
I'm having the same issue. running a Hitec Shredder RX with Hitec HS-755mg servo and CC bec. should i also (as the org. poster above) run a jumper wire from the servo back to the RX? i have the BEC powering only the servo. bec is set at 6V. Radio is old Hitec sport AM 27mhz. Green freq.
06-09-2012, 12:41 AM | #7 | |
| Re: steering glitch Quote:
You may want to go to 2.4ghz soon. | |
steering glitch - Similar Threads | ||||
Steering servo glitch?? | Stan3535 | Losi Micro-Rock Crawler | 2 | 06-13-2011 05:45 PM |
glitch glitch glitch | iluvny081 | Redcat Crawlers | 9 | 02-15-2010 08:19 PM |
Glitch Glitch GLITCH!!!!!!! | rccrawler89 | Electronics | 9 | 12-23-2009 06:41 PM |
CCBEC,Sidewinder, Steering glitch | swisherteets | Electronics | 2 | 12-27-2008 09:42 AM |
Little glitch | EeePee | Comments, Suggestions, and Help | 6 | 08-11-2005 04:55 PM |
