Thread: DX3C steering tension
Old 05-04-2012, 07:08 AM   #1
Default DX3C steering tension
How can I adjust the steering tension on my Spektrum DX3C? It says its adjustable but I don't see how.
I've found in a forum where they says its the screw in the hole near the trigger, is that right?
fabryd is offline   Reply With Quote
Old 05-04-2012, 07:51 AM   #2
Yep that's correct! mines a dx3r but it probably the same.
axman is offline   Reply With Quote
Old 05-04-2012, 08:08 AM   #3
Default Re: DX3C steering tension
Thanks.... do i have only to unscrew it to make the wheel not so tight?
Old 05-04-2012, 08:26 AM   #4
I don't know I've never messed with it I just know where it is!! Haha
Old 05-04-2012, 08:36 AM   #5
im unscrewing it but dont find improvements, it seems still tight, maybe i have to unscrew it all
Old 05-04-2012, 08:58 AM   #6
This is the best I can do for ya! Sorry
Old 05-04-2012, 09:17 AM   #7
Check to make sure your "pad" on your steering wheel is not rubbing on the tx main body. Mine used to do this on my dx3e till I glued it in place.
kennyj is offline   Reply With Quote
Old 05-04-2012, 09:20 AM   #8
thanks, btw my manual doesn't have that appendix
Old 05-04-2012, 09:29 AM   #9
Now things seems to go better
i wanted to try to unscrew it more but i dont know if the screw could pop out, i dont know if its an endless screw or not
Old 05-04-2012, 09:33 AM   #10
Hey, no prob! That's what the forums for to help each other!!
DX3C steering tension - Similar Threads
DX3c 17dean Electronics 4 11-18-2011 07:08 PM
dx3c customforlife Electronics 4 06-27-2011 09:17 PM
DX3R trigger tension? 53 willys Electronics 2 05-16-2009 08:03 AM
tension belt lock in 1/14 Joe Cool Scale Accessories 5 03-10-2008 06:40 AM
tension on o-rings S-Dog General Crawlers 9 06-05-2006 12:38 PM
