Thread: 6v dig servo at 7.4v
Old 05-11-2012, 06:29 AM   #1
Default 6v dig servo at 7.4v
Getting an 7950 soon. Running a cheap 6v servo for dig. Will 7.4 kill the servo even though it is only used when digging? Thank you for any help/comments
ax10 is offline   Reply With Quote
Old 05-11-2012, 06:47 AM   #2
Default Re: 6v dig servo at 7.4v
It will probably kill it only the once.
Its not often a 6V rated servo can hack 7.4v.
Lipos at full charge are also usually 4.2V per cell, so you will actually be putting over 8v thru at the start of the run.
stewbaru is offline   Reply With Quote
Old 05-11-2012, 06:53 AM   #3
I would run an external CC 10A BEC direct to the steering servo, let the ESC BEC run the RX & dig servo.
Problem solved.
There is an easy way to do the direct power without cutting/soldering anything.
Charlie-III is offline   Reply With Quote
Old 05-12-2012, 03:58 PM   #4
It's got a bec wired directly to the servo. So the dig servo should be running off of the esc bec?
Old 05-12-2012, 07:20 PM   #5
External BEC wired directly to the steering servo will let the ESC's internal BEC power everything else.
SMR 510RR is offline   Reply With Quote
Old 05-12-2012, 08:18 PM   #6
Yes....let her rip.....
+1.
6v dig servo at 7.4v - Similar Threads
DNA Dig Custom Servo Mounts, Full Size or Micro Servo Kraqa Axial AX-10 Scorpion 12 09-11-2009 10:17 AM
Mamba max, 11.1 1350 mil 25c, 5955tg steering servo, 5645mg dig servo BEAU Electronics 5 01-21-2009 02:36 PM
