05-12-2012, 01:08 AM | #1 |
Newbie Join Date: Mar 2011 Location: Red Rock
| Brushed Motor Timing Question
So I am cleaning my 35T Integy Motor. When I removed the can I forgot to mark it and now I've lost where the timing was set. I can see the marks on the plastic part of what i think is call the endbell? Can you just screw it down again anywhere or how can i get to how it was? Thanks Last edited by Lou-Dog; 05-12-2012 at 09:39 AM. |
05-12-2012, 06:38 AM | #2 |
| Re: Brushed Motor Timing Question
You can assemble anywhere, but a few observations. 1-If you're ~180 out of where it was, the motor will run reverse. 2-For a crawler, typically we run 0* to slight advance timing. I would start with 0* which is the brush centerline in the middle of the magnets (same as the brush centerline 90* to the vents in the side of the can). If you want a little timing, mount the motor and slowly spin the wheels in forward. See which way the motor turns. Twist the endbell 1/2 timing notch to 1 notch AGAINST the armature rotation. Lock down the endbell & run. |
05-12-2012, 07:20 AM | #3 |
Nobody Join Date: Sep 2008 Location: Maine
Here's a pic. Positive brush hood on the left, negative on the right. Spin it 180 if you truck requires reverse rotation. Last edited by Cordwood; 05-12-2012 at 09:58 AM. |
05-12-2012, 09:09 AM | #4 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
that should be the zero mark if you don't have it 180 out....keep in mind what screw you have at the zero mark, it should be a different color from the other one at least all mine are different....that's how i keep mine when i take them apart........bob .... |
05-12-2012, 09:37 AM | #5 |
I taught myself "Red on the right", two R's. And what I mean is red (positive) on the right of the notch in the can when looking at the endbell side is normal rotation. Little faster forward than reverse is good. |
05-12-2012, 09:38 AM | #6 |
Thank you for the picture and thank you everyone for the helpful posts. I will try at 0* and see how it goes. I did not know it was 90 degrees from the motor vents.
Brushed Motor Timing Question - Similar Threads | ||||
HH Motor Timing Question.. | Die-Laughing | Electronics | 14 | 11-05-2011 08:25 AM |
Brushed motor question | EMUTT | Electronics | 5 | 08-06-2011 08:59 AM |
Old brushed motor capacitor question | jclampy | Electronics | 7 | 05-06-2011 10:39 PM |
Brushed motor question | Synister_Intent | Team Losi Comp Crawler | 16 | 12-12-2009 01:36 PM |
CC Mamba Max Brushed Motor Setting Question??? | BMFOTP | Electronics | 1 | 05-06-2009 08:17 PM |
