05-19-2012, 07:20 AM | #1 |
RCC Addict Join Date: Jun 2010 Location: fort collins
| Fxr ?
I have been running my tekin fxr for awhile. I stoped using it for about 3months while rebuilding a rig. I just got it dusted off and took it out yesterday. It seems that it has a reverse delay in forward. It has never done this before. Is it possible that the settings are off, I did realize I had it set on the controler to reverse throtle. Im going to rewire motor leads today and try that. My big ? was has anyone ever had the fxr reset its memory from sitting to long?? I cant check it right now because my kids put my hotwire away and by away I mean I cant find it..lol Thanks |
05-19-2012, 07:30 AM | #2 |
| Re: Fxr ?
Sounds like it went back to factory defaults. Yes, rewire it and take the "reverse" off the TX. If you have the manual, I believe you can change almost everything without the HotWire, it's just a little harder. |
05-19-2012, 07:38 AM | #3 |
| Re: Fxr ?
Thanks.. One more question. I had it set to 3s lipo. Is that most likly reset also? and since Im kinda new to lipo's, is there a limit to the fxr on the c rating. I was running 3s 1300 25c, I just bought a 3s 2200 40c. I was just wondering so I dont let any of the magic smoke out. thanks |
05-19-2012, 07:45 AM | #4 |
| Re: Fxr ?
The FX-R manual states what all the "factory defaults" are, so go through everything. "C" rating is not in the ESC spec (except for possibly a MINIMUM rating), it is more performance related. You will be fine even if you put a 100C pack on the ESC. |
05-19-2012, 08:01 AM | #5 |
| Re: Fxr ?
Thanks for all the help. Im going to rewire it first, then I will figure out all the settings. I hope I still have the manual, or even better I hope I can find my hotwire.. thanks |
05-19-2012, 08:28 AM | #6 |
| Re: Fxr ?
Link to manual.... http://www.teamtekin.com/manuals/FXManual.pdf Save a copy on your PC as well. I have them for all my ESC's & programming cables. Makes it easier if I run into an issue out in the field, I don't need Internet access. |
Fxr ? - Similar Threads | ||||
Tekin FXR and FXR-pro ESCs in stock | JohnRobHolmes | Holmes Hobbies | 35 | 09-17-2009 09:40 PM |
