05-23-2012, 12:44 PM | #1 |
Newbie Join Date: Aug 2005 Location: PRESCOTT
| Help with wiring diagram
I have a mx-3 and want to put the 3 position switch in. I have the article and diagram from the post on dooing it but just need some help understanding the diagram. From what i can tell you remove the 2 pos switch, solider in a wire to the center post (signal) and solider wires to ground and 5 volt power. Then the 5volt goes to one side of the new switch the ground to the other but I am unclear about the center wire with the resistor as to how the resistor gets solidered in and how it works. Do you just t the resistor in to the center line anywhere and the other end of the resistor gets a wire going to ground? Can it be the same ground that the other switch wire comes from. I dont understand how this creats 2.5 volts going to the signal wite when the switch is open. Any help understanding this would be great i did a tq3 mod so as long as i have good instructions i can figure it out but the resistor is throwing me for a loop. Thanks in advance for the help. RCCrawler.com- Your #1 source for Radio Controlled Rockcrawling! this is the page i have been using.
05-24-2012, 03:31 PM | #2 |
| Re: Help with wiring diagram
Found a link to a sight in spanish. but it works!
Help with wiring diagram - Similar Threads | ||||
Need a wiring diagram | aircooled67 | Newbie General | 2 | 03-20-2011 06:51 PM |
Wiring diagram.......???? | sabohead | Electronics | 2 | 02-05-2011 02:13 PM |
need wiring diagram | fstrnu | Newbie General | 12 | 12-25-2009 10:11 AM |
who has a wiring diagram | SMUDGEBUG | Newbie General | 1 | 10-19-2007 05:44 PM |
wiring diagram | jimbobmarley | Electronics | 1 | 08-18-2006 03:25 PM |
