05-23-2012, 04:57 PM | #1 |
Rock Stacker Join Date: Apr 2012 Location: zeeland
| servo voltage
What is a safe voltage to run to a hobbico cs 170 i am running 6v right now and was wondering if anyone has experience running more voltage to it
05-23-2012, 05:19 PM | #2 |
Rock Crawler Join Date: Jun 2011 Location: Vancouver
| Re: servo voltage
lol.....good question!! I also want to know some answers well, I run 6V on my CS-170 last year and I raised up to 6.2V this year, but I didn't feel any big differences. |
05-25-2012, 12:10 AM | #3 |
| Re: servo voltage
I don't know that particular servo, but if it's rated for "6.0V" that means 6V nominal battery voltage. A 6V battery is close to 7V when fully charged, so up to 7V (actual feed) should be no sweat.
05-25-2012, 06:54 PM | #4 |
Rock Crawler Join Date: Nov 2009 Location: poteau
| Re: servo voltage
going by what olle said, if it fries and you try to warrantee it, DONT tell them you had your bec set to 7v!! they will tell you to kick rocks. this whole "6v nominal battery voltage" thing is a strange issue. do you know "for sure" that the manufacturer of the servo lists it's ratings in this manner, or do they test the servo hooked up to a power supply that supplies a constant 6v? my thinking on this is that the manufacturer is of the mind that the servo will be hooked up to a reciever that draws it's power from an esc. now this esc has a built in bec inside it and that bec supplies the power to the reciever and servo. the output of an esc's internal bec will NOT be battery voltage. it doesn't matter if you hook up a 24v battery to your esc, the internal bec will cut the voltage down to whatever it's set at. so saying that "6v nominal is equal or close to 7v" is crap. if you are of the mind to hook your servo up DIRECTLY to your battery, then this will come into play, but it is NOT what was designed or the way the servo is supposed to be hooked up according to manufacturers. |
05-25-2012, 07:15 PM | #5 | |
| Re: servo voltage Quote:
05-25-2012, 07:30 PM | #6 |
| Re: servo voltage
i think you may be missing my point, either that or i'm not putting into words what my thoughts are. lets say i take a 10v battery and hook up 200 feet of wire to it so i have terrible power loss due to the wiring. now i hook up my servo (say it's rated for 6v) and it works fine. should i say its "rated for 10v"? no. i'm NOT saying this is how manufacturers do things, BUT i am saying that if they list a specified voltage rating on their product and YOU exceed that rating, any malfunctions are on YOU. i have seen people run more voltage to servo's than they are rated for and they work fine. i've also seen servo's go up in smoke doing the same thing. here's an experiment for ya, take your servo (say it's rated at 7.4v) and up your bec output to 8.4v and run it till it burns up. now send it back for warrantee AND tell them that you had your bec set to 8.4v when it fried. let us know how they treat you. |
05-25-2012, 07:55 PM | #7 |
Pebble Pounder Join Date: Mar 2011 Location: Calgary, Alberta
| Re: servo voltage
that servo is the same as the hitec 7955 and that can run 7.4 no problem.
05-25-2012, 08:08 PM | #8 |
| Re: servo voltage
What is a safe voltage to run to a hobbico cs 170 the original question.. the answer is 6v. the hitec 7955 is only rated to 6v also. maybe these servo's can handle more voltage than they are rated for, but maybe they can't. are you going to replace his servo if he takes your advice and ups the voltage to more than the rated specs? i didn't think so. hell i've seen people run 4s batteries on esc's that are only rated to 2s. sure they worked, for a second! |
05-28-2012, 01:27 AM | #9 | |
That's what the manufacturers rely on, and the given voltages are thus the nominal battery voltage. To make the servo "look good" they of course thest them powered off fully charged batteries rather than using voltage reduction. | |
05-28-2012, 08:13 AM | #10 |
| Re: servo voltage
I feel there is a bit of an issue here. While Olle is correct in his examples (I fly 1:1 sailplanes), all his examples have equipment that have a listed "acceptable voltage range", while the original question relates to an input voltage of a fixed value. Granted, I agree that some of the servo's are stating, "nominal voltage based on direct power from a Xs pack when fully charged"..........but I also agree that if it does not state "for direct battery use" the manufacturer may make an issue. I tend to use the "nominal voltage" number whether it's from a BEC or direct from a pack. I know I didn't answer the question, just shed a bit more light on it. |
05-28-2012, 09:08 AM | #11 |
Rock Crawler Join Date: Dec 2009 Location: Redding
Just like anything you push the limits on you are increasing your chance of a failure. I look at it like this. If the manufacturer says 6v my guess is if you run it at 6v it should last a long time. If you bump to 7.4v your performance increased but the life of your product decreases. This is the same reason our 1:1 car engines run 200k miles and a NASCAR race engine gets one race at maybe 500 miles. Tuned to last or tuned to perform? That's the question only you can answer based on how deep your wallet is. But as far as warranty goes, it's clear to me when the manufacturer says 6v it says 6v. If you tell them the BEC was at 7.4 they will say the failure was caused by the user. |
05-29-2012, 12:12 AM | #12 |
RCC Addict Join Date: Nov 2008 Location: J-Braaaapin It Through Gate 10
| Re: servo voltage
I have 3 rigs with cs-170's and I run them at 7.0 all on a cc-bec and with great results and no problems, In fact 1 of them has been in my bronco scaler for about 4 years and it's still going strong. If you don't trust it then try running it at 6.5 and then go up from there and just make sure it's not getting hot. My servos get warm after a course and if I just run a battery from start to dead it gets a little warm but never to hot. Hope this helps as I don't know the limits of the servos but thats what I run mine at |
06-16-2012, 02:27 PM | #13 |
Rock Crawler Join Date: Feb 2006 Location: Cutting Comms
| Re: servo voltage |
servo voltage - Similar Threads | ||||
servo voltage | Mike5025 | Electronics | 2 | 05-03-2012 09:54 PM |
Servo voltage | Scourge18a | Electronics | 10 | 10-30-2011 01:25 PM |
servo voltage | romperstomper | Electronics | 1 | 03-20-2008 10:46 AM |
Servo voltage | thorn4run | General Crawlers | 1 | 12-19-2006 05:32 PM |
RX and Servo voltage | thorn4run | Electronics | 4 | 12-19-2006 11:10 AM |
