05-29-2012, 12:50 PM | #1 |
Quarry Creeper Join Date: Mar 2012 Location: Montreal
| 4pl and two FXr
Hi all, I have a 4pl and two FXrs in my XR10. I used Harley's guide to set it up. Did some searches, couldn't find an answer. I would like to give some negative exponential (to have a smoother start up) but if I go through "throttle" only one of the Rx is subjected to the change. I can't program FXr as it is the Reverse type and not curve... Could a bright mind enlighten me and tell me how to perform this on the 4pl? Thanks in advance! |
05-29-2012, 12:55 PM | #2 | |
| Re: 4pl and two FXr Quote:
You need to use the Hotwire to adjust throttle curves on the FXRs. | |
05-29-2012, 01:53 PM | #3 |
| Re: 4pl and two FXr
Sorry to be a pain, but there is no chan4 on the throttle menu, and no expf on chan 4 setup.
05-29-2012, 02:26 PM | #4 |
| Re: 4pl and two FXr
I only keep my throttle curves linear and never use expo. I'm at work and don't have my radio handy. |
05-29-2012, 02:31 PM | #5 |
| Re: 4pl and two FXr
Thanks for the help! I'll keep searching... I have some... heavy fingers, any help to alleviate this problem is good... my racers are all set with neg. exp. to compensate for my lack of subtlety I thought I could do without with a crawler but nope... this is worst |
05-29-2012, 05:12 PM | #6 |
| Re: 4pl and two FXr
OK now I remember. You need to activate MXMD in the Advanced dual ESC menu. That mixes the throttle settings to channel 4, so it mixes channels 2 and 4 for all the throttle settings including expo. I forget that programming this radio is so easy that you just set it and forget it. |
05-29-2012, 06:15 PM | #7 | |
I'll try this later, just had the worst thunder storm and my garage is flooded... half of the city is too... | |
05-29-2012, 06:59 PM | #8 |
| Re: 4pl and two FXr I have no idea what you mean by bias throttle (must be a French thing) but MXMD will not have any effect on proportional throttle control. It just matches the settings you put in place on throttle in chaanel 2 to mix with channel 4 or they respond the same.
05-29-2012, 07:13 PM | #9 |
| Re: 4pl and two FXr
thought bias was english, but hey... Thanks a lot Arecee! |
05-29-2012, 07:25 PM | #10 | |
RCC Addict Join Date: Aug 2009 Location: Earth?
Wish I had known that. I wouldnt have sold my 4PL after using it twice. The reverse was horrible and I tried negitive expo only to have it act like a mix and slow down one esc and not the other. Oh-well. I still prefer my DX3R anyway. | |
4pl and two FXr - Similar Threads | ||||
xr10/fxr/4pl and switching throttle to reverse | bexamous | Newbie General | 1 | 04-26-2012 01:49 AM |
Completely frustrated and absolutely confused. Dual FXR/4pl/xr10. | wyant50 | Electronics | 15 | 01-23-2012 06:23 AM |
4pl fxr issues | drpuffmd | Newbie General | 5 | 07-18-2011 12:48 PM |
New to BEC,4PL+FXR+CCBEC=? | Mr. crawl | Electronics | 16 | 06-10-2011 10:04 PM |
