06-22-2012, 06:42 PM | #1 |
Rock Crawler Join Date: Aug 2011 Location: Kingsland, GA.
| Exceed 2.4 help.
Im having a problem with an exceed radio i have. I used it with a mini 8ight and 2 rally cars with zero problems. Then recently i have tried to use it on my scaler and i can only get the steering to work. Ive tried rebinding it with no luck, and ive tried reprograming the esc also? Any ideas? I tried it with a traxxas xl5, and the goat 2s I'm using now. Thanks in advance. |
06-26-2012, 03:13 PM | #2 |
| Re: Exceed 2.4 help.
Nobody?
06-26-2012, 04:27 PM | #3 |
When you say, "and I've tried reprograming the ESC also", do you mean recalibrating the ESC to the RX? The scaler is using either an XL-5 or Goat 2S, correct? And you tried calibrating the ESC to the RX each time you swapped ESC's? What do the ESC's do when you try to run the rig? Do you KNOW the scaler motor is good? Are you using the same batteries in the scaler as you did for the other rigs? Are you sure the batteries are good & charged? |
06-26-2012, 05:14 PM | #4 | |
| Re: Exceed 2.4 help. Quote:
Exceed 2.4 help. - Similar Threads | ||||
Exceed Maxstone 8 | saddlehorse | General Crawlers | 12 | 03-03-2013 06:11 PM |
which exceed crawler | ERV JR | Newbie General | 21 | 01-20-2012 01:04 AM |
Exceed Crawlers | DSC | Superclass Crawlers | 47 | 01-16-2012 06:17 AM |
help exceed help | ax10rtrmaster | General Crawlers | 4 | 07-18-2011 07:50 AM |
exceed 1/10 | claycity | Newbie General | 32 | 01-05-2011 04:31 PM |
