07-05-2012, 10:19 PM | #1 |
Newbie Join Date: Jun 2012 Location: salinas
| dual esc wiring
hey everyone, i had a few questions on my moa build..i have a bully roller and now im working on the electronics in it...i ordered 2 mamba micro pro esc's with 2 holmes hobbies 35t motors..im new to whole moa so im getting more and more confused the more i read about wiring setups. i still need to buy a radio and was wondering whats the easiest way to hook up dual esc into a 3 channel transmitter and the whole dual esc wiring in general..any help is appreciated..thanks
07-06-2012, 06:17 AM | #2 | |
| Re: dual esc wiring Quote:
If your radio can then you use channel 1 for steering and channels two and three for the ESCs. Another approach is to buy the cheap Flysky GTB3 from Losikid on this forum which will mix the two ESCs. For a pricier option you can get the Futaba 4PL which has the dual ESC mix mode built in. | |
07-06-2012, 08:40 PM | #3 |
| Re: dual esc wiring
thank you arecee..when you run the esc's on seperate channels can you control both motors at the same time..im not looking to run dig at the moment.
07-06-2012, 11:43 PM | #4 |
That's why the tx needs mixing abilities. When it does both escs can be ran independently (fr/rr dig), same speed, or any speed in-between (proportional dig). If you have no intentions of using dig or no mixing ability you either need only 1 esc that can handle both motors or a y-harness to connect both rx wires together. Sent from my iPad using Tapatalk |
dual esc wiring - Similar Threads | ||||
dual esc wiring help | screwed | Redcat Crawlers | 16 | 04-03-2012 09:01 PM |
dual esc wiring? | john. | Newbie General | 7 | 01-10-2012 08:56 AM |
Dual ESC wiring | Ace138 | RC4WD Bully | 2 | 11-28-2011 08:54 PM |
dual esc wiring xr10 | patrol king | Axial XR10 | 5 | 11-13-2011 04:53 PM |
Dual ESC wiring ??? | AdverseCity | Electronics | 6 | 05-29-2010 03:46 PM |
