07-13-2012, 08:51 AM | #1 |
Newbie Join Date: Aug 2011 Location: ireland
| Servo problems
Can anyone help? I have included a video here http://hansmoolman.com/ (the video might take a few seconds to load). As you can see in the video, if I turn the steering all the way to the left or right and hold it there, its like the wheels turn all the way in that direction and then kinda “jumps back” a small bit from the full lock. It does this for both left and right, and sometimes the “jump back” is so severe that it almost jumps back to the steerings neutral position. Its like the servo has a hard time maintaining full lock to either left or right. Does anyone have any solutions for this problem or have anyone encountered anything similar? The servo should be plenty strong to handle the steering as it is a high torque model. And sometimes the jump doesn’t happen on which occasion it keeps the steering lock no problem |
07-13-2012, 09:08 AM | #2 |
| Re: Servo problems
Are you running an external BEC, or is your ESC powering your receiver and servo?
07-13-2012, 10:45 AM | #3 | |
| Re: Servo problems Quote:
Might the lack of a BEC be my problem? And what exactly does a BEC do? | |
07-13-2012, 11:12 AM | #4 |
| Re: Servo problems
On a side note, I dont know if it was clear from the video but my servo makes a "crackling" sound as well when powered on. I was looking at BEC's on YouTube and I saw a guy with a rc heli that was testing ESC only vs. ESC and BEC combo and his servos made exactly the same noise with only the ESC connected as my servo is making. Here is a link to his video To BEC or Not to BEC - YouTube When he hooks up his BEC the noise seems to go away so Im wondering could it be the case that the BEC will solve my problems? |
07-13-2012, 12:56 PM | #5 |
The noise is normal from a hitec servo. But I don't see a bec really helping your problem since you aren't even straining the internal bec since there is almost no load on the servo, but if it did it with a slight load to it then I would say a external bec is needed. I think it's more likely something is wrong electrically inside the servo, like either the board or possibly the potentiometer. Sent from my iPad using Tapatalk |
07-13-2012, 05:47 PM | #6 | |
| Re: Servo problems I thought so, but went back and watched as best I could for binding, and I agree, it's happening way before full lock. Only thing I saw that I didn't really care for was the connection between the servo arm and the steering rod seemed loose. No telling how old that servo is or if it's been banging around like that for quite some time. Slop like that could possibly have knocked the pot out of whack. Make sure you've got fresh batteries in the transmitter, if that doesn't fix it, borrow a known good servo, (preferably new, not sloppy), if that's smooth all the way to both sides, then install the new servo and hook it up to your truck's steering and see if that's it. Quote:
07-14-2012, 02:44 PM | #7 | |
07-14-2012, 04:25 PM | #8 |
Quarry Creeper Join Date: Jun 2010 Location: Ireland
| Re: Servo problems
Hi Hans where in Ireland are you?
Servo problems - Similar Threads | ||||
Servo problems | Jew1028 | General Crawlers | 2 | 03-12-2012 05:54 AM |
Servo problems | general lee | Chit Chat | 5 | 01-02-2010 10:22 PM |
Servo problems | CHEETAHRON | Electronics | 0 | 03-24-2009 11:43 AM |
Servo problems | paintballer9876 | Electronics | 7 | 02-01-2009 10:59 PM |
help .............servo problems | spyderzombie | Electronics | 10 | 03-27-2008 10:01 PM |
