Thread: Motor Repair
Old 08-12-2012, 09:04 AM   #1
Default Motor Repair
Hi all,
I have a Holmes Hobby 22T motor that the negative wire tab has snapped off of:
I was wondering what my options might be for repair the motor? Can I just solder on to the end bell or do I need to get an complete replacement end bell? Can I solder onto the same side as the brushes?
Sorry if these are noob questions but I don't know a whole lot about motors so any advice is much appreciated!
Thanks!
TheB1GDude is offline   Reply With Quote
Old 08-12-2012, 09:13 AM   #2
Default Re: Motor Repair
You can solder the wire to any place on that side, it will conduct to the brush. Or you can just solder to the remaining tab opposite the one that broke off. Your choice.
AreCee is offline   Reply With Quote
Old 08-12-2012, 09:13 AM   #3
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Ditto
JohnRobHolmes is offline   Reply With Quote
Old 08-12-2012, 09:25 AM   #4
Proverbial threadkiller
Trubble's Avatar
You could solder the wire back on the other side over by where the brush wire is attached,
you could go to Radio Shack (or similar) and pick up some small eyelets, solder the wire to the eyelet, and put the other end of the eyelet under the screw right near the red box in your pic,
you could send it back in to Brood or Holmes for a rebuild, and include a note to get that hood replaced,
Or, if you just don't care how it looks, you can just stick that wire anywhere on that negative brush hood.
If it were mine, I'd send it in for a rebuild,
Trubble is offline   Reply With Quote
Old 08-12-2012, 09:26 AM   #5
Nice! Thanks guys!!
How do I go about sending it in for a rebuild? Can I do it via the website?
Old 08-12-2012, 09:46 PM   #6
Originally Posted by TheB1GDude View Post
Nice! Thanks guys!!
Here is the link.
Holmes Hobbies / Holmes Bikes :: Service and Labor :: Brushed Motor Rebuild
If the tab is the only issue and the motor doesn't have a lot of run time on it I would just solder it to the other tab.
k7zpj is offline   Reply With Quote
Old 08-13-2012, 05:03 AM   #7
Originally Posted by k7zpj View Post
Here is the link.
+1. Just solder the wire anywhere on the left side of the picture, it's all the same electrically.
Charlie-III is offline   Reply With Quote
Motor Repair - Similar Threads
Touch or Repair? finishline WRCCA Rules 15 03-15-2009 10:45 PM
CC repair service setecastronomy Electronics 0 03-11-2008 02:59 AM
Driveshaft repair? INFIHunter Axial AX-10 Scorpion 27 01-14-2008 08:16 PM
Brushless motor repair? killed 3013 slugzracing Electronics 9 08-23-2007 02:26 PM
repair a moniter tltcrawlerxtrem Chit Chat 4 01-24-2007 03:48 PM
