Thread: FXR troubles... help!
Old 08-28-2012, 08:12 PM   #1
Default FXR troubles... help!
First off, I'm running a single FXR, 3S Lipo, and a HS645. No BEC, no dig, no winch, nothing extra!
A bit about my FXR: I bought it used, and added motor/battery leads. I run it inside of the Axial SCX-10 radio box (unsealed, with no attempt at waterproofing). While soldering on leads, I managed to burn through the clear part of the FXR decal (above the LEDs). I also shorted the on/off switch inside the box, close to the circuit board.
My problem: Every time I plug in a battery and turn on my Tx, I get 3 flashing LEDs on the FXR. I've tried two different radios (both work, and both have new batteries). I recently made the switch to 3s Lipo, but I re-programmed the ESC via a Hotwire.
I found the instructions to the FXR online, and under "troubleshooting" it says that a neutral signal cannot be found, and recommends re-calibrating the ESC to the radio. I did the re-calibration, and still nothing. After messing with the Tx's throttle trim, and finding a sweet spot, the ESC finally finishes it's setup and I hear the chime from the motor indicating that the radio has been found. So basically, at this point, every time I want to run my rig, I must re-calibrate my FXR. I'm not fond of doing this, Plug and play is what I'm after
Let me know if you may have a suggestions, or if this has ever been heard of.
Thanks in advance for any replies/help I receive
-Greg
grob23 is offline   Reply With Quote
Old 08-30-2012, 12:16 PM   #2
Default Re: FXR troubles... help!
So since I posted this thread I've tried: Different batteries (I tried my old NIMH packs), I've swapped between the 2 radios I have available to me, I've re-wired my truck, and I've re-positioned the wires (thinking that it could be an antenna interference problem) I think I've exhausted all options that I can think of.
I've finally found a rig that I can enjoy and be proud of, and now this... maybe it's just time to drop some coin on a BRXL!
I was kinda hoping to have this bug worked out before out G2G Saturday afternoon, but I may just give up
Old 08-30-2012, 12:25 PM   #3
Not trying to tell you what to do or trying to be mean, but I would personally steer clear of buying used electronics unless you are sure of the source. I have learned this lesson myself years ago before getting into rock crawling. I bought used electronics from someone online, and it turned out the stuff was junk. If things do not get sorted out on your own, contact Tekin and ask them if they have non-warranty services available for their products.
difflocker is offline   Reply With Quote
Old 08-30-2012, 12:39 PM   #4
Get or borrow a Hotwire from a friend and make the Neutral Band (in the FXR) larger. It could be that the person you borrowed it from tightened this way up, for whatever reason.
You may be able to adjust the neutral band without the hotwire by using the button setup.
BC-Brian is offline   Reply With Quote
Old 08-30-2012, 12:52 PM   #5
I usually don't buy used electronics, but I got it in a trade... and for a smokin deal IMO
I have a Hot-Wire, I'll mess around with it, but do you have any more information about making the neutral band wider? That kinda sounds like my problem...
Old 08-30-2012, 01:08 PM   #6
I figured it out, and that corrected my problem! Thanks a ton yo!
Old 08-30-2012, 02:01 PM   #7
I have similar issues with me fxr. But they wont calibrate.
I brought them brand new. I'm now going away from fxrs and replace all the fxrs for something better.
Good to here you got yours sorted. Dealing with tekin for warranty was always a PITA
filotr14lsdude is offline   Reply With Quote
Old 08-30-2012, 02:37 PM   #8
Finding something better will be very difficult, finding something similar will be easy. Bottom line is that most of the problems are user error, making an error in the set up or from not reading the set up sheet correctly. I've had Castle products and have been dissatisfied with them too. Recently I bought a NIB CC SW2 and it wouldn't take any programming at all. Called CC and they admitted that they had a large number of defective ESCs that could only be programmed with a CC Link. I said I didn't have one and they sent one to me without the cable.
Tekin worked worked with me to resolve a Hotwire issue with 2 RS ESCs, it turned out that my computer was at fault and killed both. Tekin replaced both within a week (shipping time).
Their CS is excellent as is their warrantiy service. I only had to use it once in over ten years and for a user error that they fixed at no charge. I can't understand what your problem was.
AreCee is offline   Reply With Quote
Old 08-30-2012, 02:43 PM   #9
I have nothing bad to say about any brand. I've been crawling for 7+ years and have ran everything from 30 dollar un-programmable esc's to high-end Castle and Tekin stuff... I've had a few problems along the way, but most were user error and/or resolved. My personal thought about ESC's is that people really need to do research before complaining about it... and that means myself too!
Old 08-30-2012, 02:54 PM   #10
I didn't get a chance to reply that you need to open up the neutral band so the ESC can read the radio signals. I usually keep it between 20 and 40 myself and that seems to work well with most radios.
Old 08-30-2012, 02:59 PM   #11
Thanks for that info too! I bumped it from 1 up to 100 maybe I should tone it down a notch...
Old 08-30-2012, 03:02 PM   #12
OMG a 1. No wonder it kept losing contact with the radio. I believe default is 50 but I can't remember and I'm at work.
Old 08-31-2012, 07:49 AM   #13
Wow, it was set to 1.... I can't imagine that is even usable. Maybe now you know why the other guy sold it. He probably changed that number without knowing what it means and could never get it to work again.
Old 08-31-2012, 08:31 AM   #14
Hey all you guys talking abut the neutral band, this is great information and now that I'm reading your experience on it's affects, I'm realizing it might also be the problem with my fxr also. The strange thing is I never changed anything in my fxr, it just one day would not arm completely... steering works, throttle flares up the led's but no motor response.
Is this the same problem you were having grob (op)? Thanks
rockhugger is offline   Reply With Quote
Old 08-31-2012, 08:41 AM   #15
Yep, if the Neutral Width is set too low (narrow) then you will have arming issues when you power the FXR up. Most radios' signal tends to wander a bit, they aren't perfectly true at the pulse width we are looking for. This feature was added to prevent runaways, if we don't see a solid neutral signal, you go nowhere until we do. I have found that about 12-15 is the lowest I can go before I start having the same issues too, on most of my ESCS, with a DX3R Pro.
Adjust the NW will change the feel of the trigger too, the larger the number, the more dead space there will be around neutral, meaning the trigger has to move further to start moving the rig. If you like the trigger to be really sensitive and throttle to be applied with the smallest movements, start bumping the NW down lower until you start seeing the arming problem, then go back up until it stops.
Ty@Tekin is offline   Reply With Quote
Old 08-31-2012, 08:51 AM   #16
Thanks Ty... I will definitely try this later after work before heading up to G-6 at the cantina event.. I hadn't seen anything posted about this in the other fxr threads on the same issue... but I'm going to say it makes the most sense since I really don't think there is anything wrong with my 3 y.o. fxr (original release v2 that's been flawless, but I'm running a gt3 radio so maybe that's part of the gremlin.
thanks again
Old 08-31-2012, 09:00 AM   #17
Ty, do you recommend using v31 over v28, or should I just leave it alone?
Thanks
Old 08-31-2012, 10:01 AM   #18
Thanks
031 is smoother, email the Prez for the download. We don't have it in the HotWire package on the site yet, still adding a few things before it goes up.
jcampbell@teamtekin.com
Also I forgot, you will probably end up needing a BEC running 3S. If your servo starts stalling out or shutting your receiver down, adding one will cure the problem.
Old 08-31-2012, 11:02 AM   #19
My problem was almost exactly the same. I'd start it up and get the initial chime, then only 3 LED's would light up, and blink. (Indicating that it couldn't find a neutral signal) The LED's would flash either the top 3 or bottom 3 depending on my throttle trigger position. I had perfect steering (and a winch with my 3ch.) but I got no throttle. Now, with the NB bumped up, I have no issues with getting it to completly arm and sync up with the radio. It works FLAWLESSLY!
That reminds me: I need to eventually grab the download for the new software. But I'm lazy so it might be a while...
I have noticed that I need a BEC. I've been crawling for long enough to know when they should be used. Plus, when someone with a status such as yours recommends it, it's a no brainer!
Old 08-31-2012, 12:41 PM   #20
I actually already did all the emailing prez and got my 031, just have not done it yet... I used this esc for years without a hotwire, and just bought when it started acting up, turns out I didn't have to, but I'm now glad I did. I never gave any background on my rig when I jumped in this thread ... but I'm running 2s for past 3 yrs. and a ccbec... gt3b radio. I actually just picked up a spare fxr 2 days ago... lol can't be down that long, but that'll go in another rig now... I love these things !!!!!
thank again ty..
yep, that's what mine and many others were going through, I might go back to those threads and put a link to this ultimately helpful thread!!! .
it's cheap insurance to run the bec either way.
off to the G-6 guys thanks
FXR troubles... help! - Similar Threads
E.s.c troubles khsderek Electronics 2 01-15-2012 03:24 PM
troubles w/ my subscription BigSki General Crawlers 8 01-29-2010 05:50 PM
Radio Troubles Blazerbogger Electronics 4 08-27-2008 03:10 PM
troubles stanbro Electronics 3 09-01-2007 05:12 PM
