09-05-2012, 02:41 PM | #41 |
RCC Addict Join Date: Nov 2004 Location: union
| Re: two fxr's two 3amp bec's why run an external |
09-05-2012, 02:49 PM | #42 |
Rock Stacker Join Date: Nov 2009 Location: hamilton, oh
it was so good, seriously I can understand why these guys risk thier lives to catch these big crabs |
09-05-2012, 02:51 PM | #43 |
Feels good to delete 11 posts all at once. Carry on with the BEC question/info. |
09-05-2012, 03:15 PM | #44 | ||
| Re: two fxr's two 3amp bec's why run an external Quote:
a.)what makes the mmp inferior to the tekin? Both are great products, the fxr is just smaller. b.)Yes, you can run them together but don't plan on there being double the current...lets say the internal bec did put out 3 amps on both of them, you won't get the extra 3 amps of power out of the 2nd esc until the first one is maxed out, and running at its max will put a serious strain on it and it'll generate alot of heat and burn up.... and the tekin guys said to run an external bec Quote:
09-05-2012, 03:24 PM | #45 |
you do get double amperage and the amp draw should be even over the two esc's. there isn't any reason it would use all of one then goto the other. It would be an equal draw over both speedo's. How many servo's even draw 4+amps? I mean even a 300 oz servo should be fine at 4-5 amps which this setup could maintain all day. And Tekin guys said it was fine, but run the bec if you want extra insurance and an easier to replace option if it did go bad. But if you are looking to save weight there is no reason not to try it, I am not saying change to this before going to the nats, but there are prolly guys who have more than one rig that could try it out. Also the MMP has a really weak bec and I would suggest running an external on it at all times. But I have found in my other tekin cars even with high powered 250oz servo's I have never needed a bec |
09-05-2012, 03:44 PM | #46 | |
And real servos are pushing 400 oz at 6.0v, then almost 500 oz at 7.4v. And that's what people are using, with 3S or more batteries. | |
09-05-2012, 03:50 PM | #47 | |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
Go hook up your 2 FXR's & go play with it. | |
09-05-2012, 03:55 PM | #48 |
people keep saying that you don't get double the amperage and that is flat wrong You get double the amperage |
09-05-2012, 03:59 PM | #49 | |||||
No it wouldn't be... Quote:
Although its rated at that, its not ideal to be running a regulator at its max output Quote:
I have burnt up a fxr thinking the same thing you are, get an external bec and save yourself $80 in the future | |||||
09-05-2012, 05:46 PM | #50 | ||
I'm starting to think this guy is just a troll... | ||
09-05-2012, 06:10 PM | #51 |
09-05-2012, 06:22 PM | #52 |
Cool, I understand what you are saying. I have a hobbico c 170 servo which is about 300 oz servo, and I will prolly upgrade from that for my xr and toss that in my scx10. I will be adding a bec to it, that was never the point. I just got to thinking, and stirred up a hornets nest. Obviously this has been dealt with many times before because you all are passionate about it. It just seemed like over kill to run a bec but let me say I GOT IT, I UNDERSTAND run the bec I just got aggravated when people started to say that the total amperage wouldn't increase when both where plugged in. When indeed it does. But simple truth is there is no way to get 7.4 volts to run this TowerHobbies.com | FUTBLS157HV BLS157HV Futaba BLS157HV High Voltage Ultra Torque Servo without a bec. Again wasn't trying to make a 75 post thread in 20 hours when I started this, lol |
09-05-2012, 06:27 PM | #53 | |
| Re: two FX-R's two 3amp BEC's why run an external Quote:
09-05-2012, 06:30 PM | #54 |
| Re: two FX-R's two 3amp BEC's why run an external Or tap into the balance plug of a 3s battery (Make sure to balance charge each time though)
09-05-2012, 06:32 PM | #55 |
09-05-2012, 06:33 PM | #56 |
yeah that would scare me considering I am running a 480mah battery. I would prolly just add the castle bec. lol yeah fighting on the internet, I must have no life, lol no one ever wins, but I feel like I got jumped into a gang or something everyone got a kick in |
09-05-2012, 06:34 PM | #57 |
BTW, RCC never loses.
09-05-2012, 06:37 PM | #58 | |
Nearly every time I've seen someone hook two of something electronic in nature together to get more power resulted in something going bye-bye in a bad way. Batteries are the exception to that... Theory vs Reality. The only time theory can win is if it coincides with reality, even then, reality still wins. | |
09-05-2012, 06:52 PM | #59 |
Nobody Join Date: Sep 2008 Location: Maine
I've got three Novak Rooster power wires all tied together on a 6x6, powering two servos. They all work great, but only because I yelled at them and they're afraid of me.
09-05-2012, 07:30 PM | #60 |
Pebble Pounder Join Date: Nov 2011 Location: Fresno
two fxr's two 3amp bec's why run an external - Similar Threads | ||||
2 Bec's in a week | Rootar | Electronics | 6 | 01-09-2011 02:19 PM |
How many CC bec's to run ? | slashbasher | Electronics | 3 | 08-20-2009 12:08 AM |
2 CC BEC's or just 1 ?????????????? | slashbasher | Electronics | 1 | 08-14-2009 04:54 PM |
