09-06-2012, 07:51 AM | #1 |
Newbie Join Date: Aug 2012 Location: colorado
| newb esc help
I got the esc in a trade and I am having a tough time finding info on it. Here is a pic. I am wanting to know if it is lipo capable. Also if it will run duel motors on a jugg transmission?? Thanks for the help. |
09-06-2012, 08:52 AM | #2 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
| Re: newb esc help
Really? Come on, I typed in LRP AI Runner Reverse in Google and this was the very first thing on the page. LRP - A.I. Runner Reverse No LVC mentioned and 18 turn single motor limit. Last edited by Scattman; 09-06-2012 at 08:59 AM. |
09-06-2012, 09:00 AM | #3 |
| Re: newb esc help
Team Associated website has the V2 model listed with absolutely no mention of an LVC. If you're going to run a LiPo, you'll need an LVA. Tower lists the minimum as a 16 turn motor, so if you're running dual motors, best make sure they're both 35 turns or higher. |
09-06-2012, 01:59 PM | #4 |
| Re: newb esc help
Low voltage alarm is cheap. Just plug it into the balance plug and set alarm for your cell count and voltage/cell you want to get to. I like 3.4v/cell because the ESC and alarm will still let it get lower. I've actually had it get down to 3.0/cell with a setup like that before.
09-06-2012, 06:51 PM | #5 |
Newbie Join Date: Feb 2011 Location: Adrian
| Re: newb esc help
I run these and have been extremely happy with them: Hobbymate 2 Cells Lipo Battery Low Voltage Monitor LED / ALARM (HBA2S) | eBay |
09-06-2012, 08:23 PM | #6 |
| Re: newb esc help
I haven't used that one. I have the integy one that has the little display on it for voltage. I use it now when I comp to see if the battery still has enough juice in it for another run.
09-06-2012, 09:52 PM | #7 |
| Re: newb esc help
Thank you I saw that site.as well just didn't make sense of it....so I can run lipo just need to retro a low voltage alarm. Is there a max cell count? Or voltage? And I am running 2 integy motors I believe they are 55t or 65t. Could that be the reason there is a noticeable lag when I tried to accelerate?
09-06-2012, 09:54 PM | #8 |
| Re: newb esc help
So that page says 4,5 and 6 cells I am assuming that doesn't mean lipo....? Also says 4-7.2v does that answer my other question?
09-06-2012, 11:05 PM | #9 |
| Re: newb esc help
A fully charged 6 cell NiXx is somewhere around 8.7-9.0 volts. A fully charged 2S LiPo is around 8.2 volts. You'd be just fine with a 2S. 3S would be a gamble. I personally think it'd be okay to go 3S with an external BEC, but not without. I could be wrong, though. |
09-07-2012, 12:21 AM | #10 |
Quarry Creeper Join Date: Aug 2011 Location: Spalding, Lincs, UK
| Re: newb esc help
Your LRP ESC will go pop on 3S, I tried it on mine and it went up straight away. I have three in cars for the kids, they are great simple ESC's, but they do have a slight lag if you put them under strain in something that needs alot of power to start moving (MT's, 4wd buggies etc). They are fine in lightweight cars, I have mine in TA01's and M03's with 21 and 23t motors where they are faultless
09-07-2012, 01:53 PM | #11 |
| Re: newb esc help That is pretty slick - I have not seen that one before. Thanks for the heads up! |
newb esc help - Similar Threads | ||||
Newb ESC problem | slammin1984 | Electronics | 6 | 12-27-2010 09:34 PM |
Newb with ESC questions | Casey429 | Axial SCX-10 | 3 | 12-27-2010 03:03 PM |
ESC types for a newb | LittleDave | Electronics | 6 | 07-20-2009 10:33 PM |
NEWB: ESC with brakes? | Turboduck01 | Newbie General | 3 | 08-06-2008 04:48 PM |
ESC help for the newb | Tutt | General Crawlers | 19 | 06-12-2004 02:25 PM |
