09-16-2012, 07:07 PM | #1 |
| Should I build a 4 Wheel Steering Controller?
Help me out here. Is there any need for this item? This controller will operate your rear steering servo based on the position of a three position channel.
This device would plug into CH1 and CH3 (or some other channel if you have a bunch) of your receiver. It will also have connections to the front and rear servos. I think there may be others selling a similar product, but I will try and make the best one possible. Light, small, and waterproof, and at a reasonable price. I will stand behind it like I do all my stuff! Please let me know what you think. If more than two or three guys think they would be in the market for one, I will consider offering them. Thanks for your time. Al |
09-16-2012, 07:12 PM | #2 |
Quarry Creeper Join Date: Feb 2012 Location: Arkansas
| Re: Should I build a 4 Wheel Steering Controller?
I'd buy one!
09-16-2012, 07:21 PM | #3 |
Sounds like a great idea. Especially if you do it to the same quality level of your other offerings. As for me, I have no current plans for 4WS...sorry. If I did go 4WS, I have a hacked GT3B. If nothing else, free bump. |
09-16-2012, 07:24 PM | #4 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
awaiting for the product....
09-16-2012, 07:55 PM | #5 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
I think punk made one at some point. Seemed interesting to me.
09-17-2012, 04:14 AM | #6 |
I wanna be Dave Join Date: May 2010 Location: The east coast
if the price is reasonable i might be interested. got a 6x6 i'm building with all axles being steered (2 up front, 1 rear axle) so being able to normal and crab steer would be nice.
09-17-2012, 06:54 AM | #7 |
Thanks for the replies. Okay, I'll see what I can do. |
09-17-2012, 09:50 PM | #8 |
Newbie Join Date: Feb 2012 Location: Tracy
I also would be in use of one if you make them i will buy one for sure starting my 6x6 tow truck!
09-18-2012, 09:22 AM | #9 |
I've made a lot of progress with this. The basic functionality is there - all three of the modes I mentioned are working. Now to do some of the finer points. I would rather not, but I think it needs a couple of controls. Trim and End Point Adjustments. The Trim so that it will track straight and the End Point Adjustments so that the servo doesn't try and push the linkage beyond its mechanical limits and break things. I wish I could do it without these things. Pots are susceptible to water damage, but they are really the nicest way to set these adjustments. Still, it might not be so bad. Once they are adjusted, some plastidip or silicone could be smeared over them to keep the water out. The next decision is to use two or three pots. One as I said is for Trim. The other two for the End Points, or , I can reduce that to one pot. That control would be used to limit the total swing. Does it make any difference to you guys weather there are two or three pots? |
09-18-2012, 09:28 AM | #10 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
i would buy one
09-18-2012, 10:02 AM | #11 | |
| Re: Should I build a 4 Wheel Steering Controller? Quote:
09-18-2012, 10:26 AM | #12 |
| Re: Should I build a 4 Wheel Steering Controller? |
09-18-2012, 06:44 PM | #13 |
Pebble Pounder Join Date: Jul 2009 Location: Lehigh Valley, PA
If this requires a three position third channel, why not just skip the controller and plug the rear steer directly into the third channel? I think Punk's worked without a third channel and used a steering and throttle sequence to activate the rear steer.
09-18-2012, 07:39 PM | #14 | |
The throttle sequence sounds clever and maybe annoying, but still an option if you didn't have a channel available. | |
09-18-2012, 08:13 PM | #15 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
id be interested.. problem with the hacked 3b to me is that (my lack of understanding) is you have to go through the menu to do each set... id rather just run a Heli controller to get all the channels.. but id be interested in to see what you got and how..
09-18-2012, 08:28 PM | #16 | |
The GT3B/C can do a multi position channel. So instead of three positions, maybe have four or something. Feed that into my steering controller and have another mode. Maybe
Start making too many options and it is hard to keep track of everything though. I probably won't do much coding before the weekend, but should have something to show by Sunday if all goes well. | |
09-18-2012, 10:17 PM | #17 | |
What do you mean you have to "go through the menu to do each set"... | |
09-19-2012, 06:21 AM | #18 | |
The regular steering signal then gets copied out to the rear servo or it gets inverted for crab steer or it just stays centered to lock the rear servo in the middle. To come up with a Trim, Left End Point and Right End Point, it will do a little math on the pulse widths. Last edited by heyok; 09-19-2012 at 06:24 AM. | |
09-19-2012, 06:39 AM | #19 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
Id buy one. In the process of setting up rear steer on my rig now and it would be nice to have those options. Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 |
09-20-2012, 05:53 PM | #20 | |
well i was going to throw my own thread up when i had the cash together.. i would assume.. if im driving with front steer only... i would drive.. i get up a few rocks... then if i need to crab walk.. id have to go through the menu and choose it... then drive.. then menu to choose opposite steer... etc... is that how the hacked one works? that is why i was thinking of using a heli controller.. i can choose to do what i want when i want.... unless i am missing something with the hacked controller.. trust me i would love to support losikid... all for helpin forum members out..... i figure heli controller... left stick fwd/rev on left... left/right front on right... then take time to get used to rear left/right with left stick.... | |
Should I build a 4 Wheel Steering Controller? - Similar Threads | ||||
Wraiths spare tire mod with 4 wheel steering build - help | bikeboy | Axial Wraith | 2 | 10-08-2011 03:45 PM |
HK controller steering | smiley-1988 | Electronics | 4 | 09-30-2011 12:58 PM |
Controller Wheel Squeak | Suicide Jockey | Electronics | 1 | 07-02-2011 07:08 AM |
steering stops on a MRC controller? | skid | Electronics | 0 | 03-13-2009 01:08 PM |
Wanted: Nylint Controller Steering Wheel 1:6 | MonkeySee | General Crawlers | 5 | 09-12-2006 02:40 AM |
