10-01-2012, 02:57 PM | #1 |
Rock Stacker Join Date: Sep 2012 Location: moscow mills
| esc question
ok Im building a Xr10 I just ordered 2 35t integy motors, now Ill never compete with this rig, and would like to only use one esc , at least for now, I thought i read somewhere that if you run two 35t motors in parallel it comes out to be 17.5t that the esc sees? Is that true? I have a old xl-5 traxxas esc( that has lipo cut off) Id like to use if it can run two 35t motors
10-01-2012, 03:26 PM | #2 |
| Re: esc question
Do yourself a favor and buy a decent ESC, why buy a top of the line comp crawler and throw junk in it? Putting a XL-5 in a XR10 is like putting a Hyundai engine in a Ferrari. Grab a FXR and a dig switch and you will be much happier, the lack of drag brake on the XL-5 is really going to limit the possibility and without at least front/rear dig there is no point in having a MOA crawler. I hate to say it but if you just wanted to mess around a SCX-10 would have probably been a better purchase. They are fun and you dont have to throw tons of money at them. To answer your other question, yes two 35t motors are the equivalent of running a single motor @ 1/2 the turns. The ESC doesnt "see" anything but the amount of power the motors will draw is what is important. |
10-01-2012, 03:56 PM | #3 |
| Re: esc question
Im sure in time, when it wont do what I like, Ill be doing up grades lol but for now I just want to get it moving and I have to work with what I have, lol the "budget master" tries to keep a tight reign on me .... so thanks for the input but
10-01-2012, 06:08 PM | #4 |
| Re: esc question
In my experience, the XL-5 tends to run warm to hot when asked to go slow. And that's on one 35 turn motor and 2s. I hated mine for lack of drag brake and lousy low speed control, right until the magic smoke came out and gave me a good excuse to get a real ESC. I settled on a Holmes BRXL, but a Tekin FXR would likely fit much better in an XR. If it's temporary, sure wire it up and go play. I wouldn't expect it to last long though. Runing the smallest pinions you can will help reduce ESC temps. Hopefully it will last long enough for you to really desire separate front and rear motor control. |
10-01-2012, 06:33 PM | #5 |
| Re: esc question
You CAN'T get a turn limit by simple math. While it seems OK, it's usually worse for the ESC. I would suggest an older used CC Mamba Max to run 2 35T motors. Great drag brake, more likely to last with your motor choice. |
10-01-2012, 06:53 PM | #6 |
Rock Crawler Join Date: Dec 2011 Location: Las Vegas 89110
| Re: esc question
the rc4wd dual motor outcry esc is a cheap great working option
10-01-2012, 09:24 PM | #7 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Re: esc question
The best budget friendly esc is probably a sidewinder. They have decent drag brake, and will run 3 motors without issue.
10-06-2012, 03:48 AM | #8 |
| Re: esc question
has anyone ever used the punk dig 2+ for a two channel radio system?
10-06-2012, 07:07 PM | #9 |
Rock Crawler Join Date: Mar 2012 Location: bel air
| Re: esc question
says on the rc4wd site the outcry is a 1 motor unit... rated for 300a?!?!? but one motor? i am trying to find a decent esc for my clods..
10-07-2012, 09:55 AM | #10 |
| Re: esc question
traxxas electronis are for people that cant afford the good stuff |
esc question - Similar Threads | ||||
esc question | Red_13 | Electronics | 27 | 03-11-2012 08:15 PM |
ESC question | gates59 | Newbie General | 12 | 05-06-2011 08:19 AM |
Question about my ESC | NoobAxialCrawler | Axial SCX-10 | 6 | 02-16-2011 09:55 PM |
Question about esc. | crawler99 | Axial AX-10 Scorpion | 3 | 08-30-2010 07:39 PM |
esc question | U4EAH | Electronics | 7 | 02-02-2008 02:58 PM |
