Thread: Airtronics or HiTec High Torque
Old 09-26-2012, 05:14 PM   #1
Default Airtronics or HiTec High Torque
Im trying to decide between the Airtronics 94780 which has 423oz @6.0v and the HiTec 7950TH which has 403oz @6.0v and 486oz @7.4v.
I can get the Airtronics for 115 and the HiTec will cost about 140.
Is the HiTec worth another 25+ dollars for another 60oz. Its going in an SCX10 TTC rig with BRXL and castle BEC Pro. Thanks for help and or advice.
Sent from my Samsung Galaxy Note (Phablet)
AsILayDying is offline   Reply With Quote
Old 09-26-2012, 05:49 PM   #2
Default Re: Airtronics or HiTec High Torque
I run the 7950, but I get them for ~$120 shipped, I think it's "power hobbies" and they have an Ebay store & are located in Sufferin NY.
Also check ServoCity, they have deals all the time.
Charlie-III is offline   Reply With Quote
Old 09-26-2012, 06:00 PM   #3
ServoCity has the 7950 for 149.95 and power hobbies does not have it, they have the case replace kit. And the best online price is like 139.00 So Im trying to figure out if the extra price is really worth it.
Old 09-27-2012, 01:49 AM   #4
7950 all the way. I wont run any other brand servo either. High Tec kicks ass.
crawler nut is offline   Reply With Quote
Old 09-27-2012, 02:14 AM   #5
Been running the Airtronics 94780 with a brxl no bec and runs good. Not noisy like my other hitec's....both very good servo's.
Erbing is offline   Reply With Quote
Old 09-27-2012, 09:36 AM   #6
i've seen the airtronics 94780 split the case into before. after seeing that i would stick with the hitec. i know all servo's can break, but i've never seen any other servo split the case like the airtronics did!
hoghead5150 is offline   Reply With Quote
Old 09-27-2012, 04:11 PM   #7
mrG
I been running the 7950 for a few weeks and an totally happy with it, and just looking at the specs the hitec is the winner. That's why I chose it. I bought mine at the crawler store for 130.
mrG is offline   Reply With Quote
Old 09-27-2012, 04:36 PM   #8
I found some 7950's on eBay for like 115.00 new. They were just take offs from kits. I don't know how that affects the warranty but I haven't had any issues with it. The 7955 and 7954 are different stories though as I have broken the gears in both. Also tower list another hitec that has similar specs but they are newer models and over 200 bucks. I forget the model number but its in one of my catalogs
Sent from my DROID RAZR using Tapatalk 2
irokcrawl is offline   Reply With Quote
Old 09-27-2012, 04:45 PM   #9
I think its the HSB-9380TH which pulls less power and can be maxed out indefinitely without damaging the servo. Something like 480oz at 7.4v
Old 09-27-2012, 05:44 PM   #10
Guess ill try to get a 7980 seems like a pretty good servo. Just don't want to spend 100+ and be disappointed in performance.
Old 09-27-2012, 06:00 PM   #11
Keep in mind the 7980 is a large servo, it may have fitment issues in tight rigs.
Old 09-27-2012, 06:08 PM   #12
I meant 7950th. My bad.... Been looking at so many servos got mixed up.
Old 09-29-2012, 05:22 PM   #13
im running a Airtronics 94780 in my 2.2 rig so far i have no complaints at all, its stronger than i think i need but i can move some rocks with it if needed
kunas is offline   Reply With Quote
Old 09-29-2012, 05:46 PM   #14
I run a 7950....so far no complaints (using an external CC BEC).
I also run a Futaba BLS157 (?) on an external BEC. It's the only non HiTec servo we run in crawlers.
Old 10-07-2012, 11:19 AM   #15
tuner's Avatar
Haven't had a problem with my 7950 running 7.4 volts in my 2.2 comp crawler for two years. I know a few people who run them in ther supers and in their wraith so yeah get the 7950.
tuner is offline   Reply With Quote
Airtronics or HiTec High Torque - Similar Threads
Hitec HS-645MG High Torque Servo Azcats1 Newbie General 7 01-12-2006 05:07 PM
