05-02-2014, 12:49 PM | #21 |
Newbie Join Date: Aug 2012 Location: Vancouver
| Re: Trouble with Axial NVS....
Interesting comments, Alexandru, about DSMR. I just found this thread after sending an e-mail to Axial support this morning. Here are my issues with NVS after installation on a Deadbolt with custom headlights and tail lights installed: Headlights (White 5mm x2) in Head Light connector Tailights (Red 5mm x2) in Brake Light connector Auxiliary Axial Light Bar (White 5mm x2) in AUX connector I did not use the turn signals nor do I care about brake lights necessarily. The taillights flicker going forward as do the headlights and light bar but not as much as the taillights. They do not flicker in reverse. It the head lights and tail lights are plugged into the upper Auxilliary light connectors, they do not flicker forward or reverse. I can live with that. The light bar shows very slight flicker, and I could live with that but would prefer not to. The unit is connected as per instructions. I am using 2s battery, Spektrum SR410 receiver, original ESC and steering servo, no BEC, and Spektrum DX4S radio. I will report back what Axial replies. |
06-25-2014, 05:48 PM | #22 | |
Newbie Join Date: Mar 2014 Location: By Da Swamp
| Re: Trouble with Axial NVS.... Quote:
Update... well, I traced it back to the Savox servo. I plugged in an older one, and it seems to work now. Sill not sure if it's a voltage problem or just the mfg. If anybody has the answer, please let me know. TY Last edited by Howler; 06-25-2014 at 08:38 PM. | |
08-14-2014, 08:54 PM | #23 | |
Newbie Join Date: Jan 2009 Location: Canada
THANK YOU FOR THE CLUE! I am also running a new DX4 on my G6 with NVS and was having the annoying "left turn signal" all the time and "pulsing" lights. Here is how I solved the blinker issue: 1. I simply connected the NVS Steering Input to Aux1. 2. Connected the steering servo back to the steering channel of the Rx. 3. Went into the DX4 menu and selected "Steer Mix". 4. Then selected the type to be "Dual AX1", left trim ACT for now and Rate at 100% each direction. Now when I turn the wheel, the mix uses Aux1 as well and the blinkers work as they should. So there is something funny about the steering channel on the Rx. Why it doesn't simply output a clean 1500us on center and 1000us to 2000us for min and max is beyond me. I'll pull out the scope meter and have a look at it one of these nights. --- To temporarily solve the pulsing headlight issue, I connected them to an Aux channel until I can chase that down. Cheers Tim Quote:
Trouble with Axial NVS.... - Similar Threads | ||||
Trouble with Axial NVS system | gobo | Newbie General | 20 | 09-21-2014 10:38 PM |
Axial NVS vs. 3Racing? | DRW-FJ40 | Scale Accessories | 6 | 09-04-2011 08:19 AM |
Axial nvs | Jay2380 | Electronics | 0 | 05-26-2011 11:32 AM |
Axial NVS Instructions? | Knytemare | Electronics | 3 | 12-05-2010 07:05 PM |
Axial NVS alternative | neo | Axial SCX-10 | 1 | 04-16-2010 06:37 AM |
