10-28-2012, 02:32 PM | #1 |
Quarry Creeper Join Date: Nov 2010 Location: Montreal
| 3S lipos too hard on brushed motors?
my firend and I got both Holmes hobbies torquemaster motors, he run his on 3S and I run mine on 2S...he told me today that he has to clean up the contacts on the rotor before almost every runs he does because they have black spots on them..(like spark spots) I checked mine just for fun and they are clean as they could be...we both run at the same places and we never go in the water....could it be the 3S batteries too hard on the motor?
10-28-2012, 02:35 PM | #2 |
| Re: 3S lipos too hard on brushed motors?
Most people here run 3s on their brushed motors, some run 4s or higher. I doubt that is what is causing his problems... I would have him contact holmes and see what he says although I bet he will see this and put in his comments. |
10-28-2012, 04:00 PM | #3 | |
| Re: 3S LiPO's too hard on brushed motors? Quote:
Not sure what the OP issue is unless they're running in mud or lots of dust/sand. | |
10-28-2012, 06:13 PM | #4 |
I ran my TM for nearly a year before I checked the brushes or pulled it apart to clean it out. All that time it was on 3s.
10-28-2012, 08:53 PM | #5 |
Rock Stacker Join Date: Jan 2009 Location: halfway
check the timing! sounds like that may be the problem.
10-28-2012, 09:15 PM | #6 |
Quarry Creeper Join Date: May 2012 Location: My own personal Heaven
I have this same problem, mine is timed according to JRH's recommendations. I ran it for the first time today on 3s and it crapped out 1/3 through a run. :(
10-29-2012, 09:08 AM | #7 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
I have been running one pair of brood motors on 3s and 4s for 4 years without so much as opening the can or looking at the brushes. No issues out here.
10-29-2012, 09:15 AM | #8 |
3s is harder on motors than 2s. I would suggest that the timing is checked and that a clean motor is a happy motor.
10-29-2012, 10:08 AM | #9 |
thanks for all the infos! I will check my timing as well..I dont think I did anything when I got the motor...I just use some air to clean it and that's all for now...i'll tell my friend about the timing too!
10-29-2012, 10:30 AM | #10 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Might wanna check gearing....if you guys are running the same gearing, but you are on 3s, you should be running a smaller pinion or bigger spur.....motors geared wrong will burn up faster.....sometimes they will blow up. Later EddieO |
10-29-2012, 03:01 PM | #11 |
Pebble Pounder Join Date: Jun 2012 Location: Canada
I heard this somewhere around these forums.... gear down, volt up... |
10-29-2012, 10:04 PM | #12 |
Rock Stacker Join Date: Mar 2012 Location: longview
Hows he cleaning the comm? He should have it cut and install new brushs Gear down a little |
11-01-2012, 07:19 PM | #13 |
Rock Stacker Join Date: Feb 2012 Location: Kelso,wa
Maybe put some new brush springs on. If its ever been overheated, spring tension will be lower thus causing the brushes to bounce and arc on the comm. before you know it there will be crud between the brush and comm making a poor path for electricity. Just a thought and good luck.
11-01-2012, 07:33 PM | #14 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
How is he cleaning the comm? If he's using sand paper or something similar he's probably creating his own problem.
3S lipos too hard on brushed motors? - Similar Threads | ||||
Brushed Motors | Needboost | Electronics | 4 | 08-21-2011 06:42 PM |
Brushed Motors | DustyfX4 | Electronics | 7 | 03-15-2011 04:16 AM |
No more brushed motors for me! | Scattman | Chit Chat | 3 | 07-04-2006 03:36 PM |
