11-07-2012, 09:02 PM | #1 |
Rock Stacker Join Date: Aug 2012 Location: ontario
| 7954 hitec-servo turns wrong direction?
New out of the box 7954... When laid down like to mount it [Wraith] the servo stops turning in the middle but will turn all the around to the top? You know it has to turn left and right... do you set the horn somewhere to get it right? or is it this program thing? the damm instructions sheet wording is so small I can't read it. to scared to plug it in to the rx to find out! Big comp coming up and need it. Jeez, do I sound like a NooB. |
11-07-2012, 09:04 PM | #2 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Take the servo horn off and install the servo. Turn your rig on and it will Power up the servo and it will center itself. Now that it is on and centered install your servo horn. All fixed |
11-07-2012, 09:07 PM | #3 |
Quarry Creeper Join Date: Mar 2009 Location: in a van down by the river
11-07-2012, 09:49 PM | #4 |
| Re: 7954 hitec-servo turns wrong direction?
Hey Ok, easy enough! I wonder what happened...is there not a set pin in the large gear to hit the stop blocks inside on the case? Thanks again.. |
7954 hitec-servo turns wrong direction? - Similar Threads | ||||
AX10 only turns one direction? | LeadFarmerAK | Newbie General | 5 | 02-17-2009 01:08 PM |
