11-10-2012, 11:08 PM | #1 |
Newbie Join Date: Sep 2012 Location: Sapulpa
| Tekin FX-R problem.
Just got a Tekin fxr on my SCX10 and got it all situated and installed. Calibrated it, set it in the settings. It works for a minute then the motor stops. ESC shows signal and responds to inputs, steering still works. Adjusting settings doesn't make the chime sound. If I turn it off for a minute it will work fine, then have the same problem again. Everything is hooked up correctly, double checked. No wires pinched or cut. Any ideas what may be going on?
11-10-2012, 11:16 PM | #2 |
Rock Crawler Join Date: Jan 2009 Location: Boise
Did you check to see where you lipo cutoff is set at? Sent from my Xoom using Tapatalk 2 |
11-10-2012, 11:18 PM | #3 |
| Re: Tekin FX-R problem.
Set to 6 volt 2S. That's what my battery is. My stock esc did the same thing, that's why I got the fxr. Now it is doing the same thing
11-10-2012, 11:33 PM | #4 |
Rock Crawler Join Date: Mar 2009 Location: East TN
Sounds like its not an esc problem. I'd find a motor that you know works and check it. May be the motor going bad.
11-10-2012, 11:38 PM | #5 |
I'll try the stock motor. The motor in it now is a brand new 55T.
11-11-2012, 01:19 AM | #6 |
One of 3 things can be the problem...
With some swapping of parts it should become obvious what is causing the problem. |
11-11-2012, 03:35 AM | #7 |
Newbie Join Date: Jul 2008 Location: united kingdom
have you tried turning the cutoff off alltogether and have you also tried different batteries and connectors
11-11-2012, 09:13 AM | #8 | |
| Re: Tekin FX-R problem. Quote:
5. Brownout due to no BEC. | |
11-11-2012, 10:02 AM | #9 |
Do I need a BEC? 2S 5000mAh, 25C lipo, balanced regularly. Never had this kind of problem, much less on two different ESCs. Going to swap motors today and see. At least it is raining this morning, good time to wrench.
11-11-2012, 11:45 AM | #10 |
I do need a BEC. Just saw the sticky. Duh. |
11-13-2012, 01:39 PM | #11 |
Installed a CC 10Amp BEC. Same result. On the fxr there is a temperature display. It gets hot in like two minutes and shuts off the motor. It isnt over geared and nothing is binding. Tekin suggests sending it in to check it out. It's like brand new. Any other ideas?
11-13-2012, 02:27 PM | #12 |
Newbie Join Date: Apr 2012 Location: savannah
so dont get the fx-r?
11-13-2012, 05:02 PM | #13 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
Are there lights flashing and if so which ones?
11-13-2012, 05:38 PM | #14 |
Under normal use it only blinks the on and flashes the temp range. But the temp range goes up fast and thermal shutdown happens till it cools. I changed motors back to the stock and recalibrated and just to check went with default options ( voltage cutoff OFF) and no problem. As soon as I changed the settings and used lipo cutoff (2S) it went back to shutting down and getting hot. I know I can get an hour plus on a pack and I rarely crawl that long continuously, so I may just turn it off and keep an eye on the voltage or get a voltage alarm.
11-13-2012, 05:50 PM | #15 |
What gearing are you using? And which lights are coming on? 1 and 3, 1 and 4....etc.
11-13-2012, 05:56 PM | #16 |
Pebble Pounder Join Date: May 2010 Location: Ephriam, Utah
Need to know gearing of your rig? What motor are you running? Do you have Hotwire? check your connections. Do you have the cap on? Is it working correctly?
11-13-2012, 06:00 PM | #17 |
When the lights flash lights 1-5 flash. But not the error flash mentioned in the manual. I have a 15T pinion and stock spur 87 or 89 I think.
11-13-2012, 06:23 PM | #18 |
I am confused here. What error are you referring to from the manual?
11-13-2012, 06:34 PM | #19 |
Quarry Creeper Join Date: Dec 2009 Location: At your moms,she says hi!
| Re: Tekin FX-R problem. |
11-13-2012, 06:36 PM | #20 |
Tekin FX-R problem. - Similar Threads | ||||
Problem with Tekin RS system in my LCC, will a BEC fix my problem? | rcboy514 | Electronics | 3 | 01-12-2012 05:55 PM |
Tekin Problem or Radio Problem? | Harvo | Electronics | 8 | 07-30-2010 06:02 AM |
Tekin RS 21.5 problem | wrightcs77 | Electronics | 2 | 05-19-2010 07:44 AM |
Tekin Rebel 2 problem | ROCKAPE | Electronics | 2 | 01-22-2007 05:00 PM |
Tekin rebel 2 problem | shadow | Electronics | 8 | 06-14-2006 11:00 AM |
