Thread: Problem?
Old 11-11-2012, 01:41 PM   #1
Default Problem?
Hey guys i have an exo and i am running a mmp with a bec with a tekin 4600kv brushless motor sensored and an align servo. all is brand new. i went outside to try it out and if i instantly full throttle the car will move but it stutters, but if i gradually ease in to it it will run fine. I am wondering if this is something in the esc, motor, or what? let me know if you can help .
thanks
TRUBLE is offline   Reply With Quote
Old 11-11-2012, 02:25 PM   #2
Default Re: Problem?
What gear ratio are you running on your Exo?
Also, try posting in the Exo section over at rcshortcourse.com, you might find more Exo help there.
ShortCourse & Desert Brand Specific Tech - Axial EXO Terra Buggy at RCShortCourse.com
k7zpj is offline   Reply With Quote
Old 11-11-2012, 02:40 PM   #3
Same issue here. Turned out to be the sensor cable on mine. Found them to be real fussy.
40 grit is offline   Reply With Quote
Old 11-11-2012, 02:42 PM   #4
I found out that it was the sensor wire. I removed it and changed the mmp to smart sense and it runs great.
Problem? - Similar Threads
Problem with Tekin RS system in my LCC, will a BEC fix my problem? rcboy514 Electronics 3 01-12-2012 05:55 PM
Tekin Problem or Radio Problem? Harvo Electronics 8 07-30-2010 06:02 AM
Little bit of a problem, Possibly big problem... C_Money Electronics 11 03-08-2010 05:49 PM
Charger problem or power problem? Rockfrog Electronics 4 10-09-2009 01:10 PM
* Problem * Clicking Problem on my 1/18th clodman General Crawlers 6 04-08-2006 08:40 AM
