11-21-2012, 06:23 PM | #1 |
Quarry Creeper Join Date: Jun 2012 Location: Earth mostly
| Tekin Hot Wire/Castle Link review
I bought a Tekin FXR with 35T motor and a Hitec servo with castle BEC for my Axial Honcho. I wanted more torque, better drag brake and I really didn't like the stock servo. I decided to get the Hot Wire interface and Castle link. The castle link was pretty simple since all I did was up the BEC voltage to 7.4 for the servo. Did what it was supposed to I measured the voltage before and after. To do a fair comparison I programmed the ESC with the Hot Wire then reset everything and did it manually.I have to say I thought the Hot Wire was just a gimmick to make money but after using it I would rate it 9/10. Pros - downloaded and installed in about 5 mins super easy - took me about a 30s to hook it up to the ESC no harder than pressing the buttons -once it connected everything is pretty self explanatory, I was able to set everything up the way I wanted on the first try -you can reset everything to default settings any time you want, I know a few times on my Traxxas ESCs I got lost trying to follow all the flashes and messed things up then spent an hour trying to figure out what I did - way more convenient and simpler than trying to use the buttons and LEDs I can do in 10s what takes 15min with the buttons -I have really big hands and since I mounted the FXR and reciever in a box I find it hard to press the buttons with all the wiring in there, I have to use a pen - Updated my ESC to the latest software version I don't think you can do this any other way, I tried it before and after the update didn't really notice any difference so not sure how useful this is. Maybe somebody with a very old version or some glitching may notice something. Cons - you need a computer to use it so unless you pack one with you you'll still have to use the LEDs to make field adjustments -it does cost $30-$40 for something you can do for free just takes a little more time and patience -you may not take the time to learn how to manually adjust the ESC All and all I would buy it again. Last edited by xCoolHandLukex; 11-21-2012 at 06:25 PM. |
11-21-2012, 06:35 PM | #2 |
| Re: Tekin Hot Wire/Castle Link review
I feel the HotWire is better than doing "button pushes", but yes, it requires a PC. The Castle Link is similar with one GOOD exception......you can save a ESC profile, then copy it to multiple ESC's. Not an issue with a single ESC rig, great for dual ESC rigs or, multiple rigs. In general, I give to the Castle stuff. |
11-21-2012, 07:17 PM | #3 |
I like to try different brands and compare them. I bought a Novak system for my Night Crawler and I want to get a Castle set up for my Summit and maybe my Slash then I`ll be able to try the Castle Link out a little more. There BECs are awesome I have 3 now and after water proofing and setting the voltage on them I haven`t had a single problem. Does castle make a pre-packaged Crawler system ?
11-22-2012, 01:20 PM | #4 |
Rock Stacker Join Date: Sep 2012 Location: Goshen
Thanks for taking the time to post this. I just purchased the fxr and the hot wire. Also have the castle link all ready. I know the castle is great but it's nice to know I made another good (lucky) choice with the fxr and hotwire.
11-22-2012, 01:24 PM | #5 |
Rock Stacker Join Date: Aug 2012 Location: mchenry
I wouldn't use the 029 or 030 firmware update for the fxr yet. There having programming issuses with them. Is stick to 028. Won't notice it. I fried 2 fxr with the update. Lucky tekin replaced them free of charge.
11-22-2012, 08:24 PM | #6 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
| Re: Tekin Hot Wire/Castle Link review I think some were good and some were bad. I've been running both mine on version 030 since I've had them. |
11-22-2012, 09:22 PM | #7 |
One of mine has Ben fine on 030. The other 2...up in smoke. Just trying to help prevent a headache.
Tekin Hot Wire/Castle Link review - Similar Threads | ||||
castle link & hot wire question | crawlski | Electronics | 11 | 07-27-2011 04:12 PM |
Need tekin hot wire help for scaling | The Doc | Electronics | 3 | 11-30-2010 09:23 AM |
tekin hot wire | killrocks | Electronics | 2 | 03-02-2009 11:32 AM |
Hot Wire vs Castle Link | robvbro81 | Electronics | 7 | 01-15-2009 10:37 PM |
