11-28-2012, 07:26 AM | #1 |
Rock Stacker Join Date: Aug 2012 Location: ontario
| Hitec Servo Caps FYI
Hi, broke one side of the mount cap on a new 7954s [@90 minutes run time]. Hitec Service department did respond to email and said cases are not warranted. Their reply did not state year warranty is void when servo is opened as stated in the information sheets included in servo package. Also a link for a replacement case was provided. I bought a product with a good quality reputation but was unaware of some fine print. FYI Some RC friends have never heard of a ear or tab breaking off while others admit the case plastic on Hitec are a brittle type. I just picked up the rig from its side and let it drop to the ground waist high and she broke. A case is in the mail provided by the LHS. Thanks. I HAD TO MAKE A BIGGER MOUNT!. Mock up and good to go. |
11-28-2012, 08:15 PM | #2 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
| Re: Hitec Servo Caps FYI
And that's why you drop it on all fours instead of its side. It look slike a bad batch of plastic for that case. I've had my 5955 for 2 or 3 years and haven't had a problem.
11-29-2012, 09:54 AM | #3 |
Hmmmm.....1st broken HiTec case I've seen. Was it cold out? If so, almost ANY plastic we use gets brittle when cold and will NOT handle shock loads well. I will also guess you will be asking about replacement servo arms at some point, even the 7954 will strip out the plastic horn at some point. I suggest a GHRacing (AKA, Golden Horizons Racing) clamping style aluminum horn. It's ~$8. |
11-29-2012, 10:05 AM | #4 |
Rock Crawler Join Date: Sep 2011 Location: truckee
Get some servo clamps too.
11-29-2012, 10:08 AM | #5 |
Thanks for the horn suggestion, will check it out. The air temp was a nice day! 60-65f |
11-29-2012, 10:24 AM | #6 |
Rock Crawler Join Date: Jun 2009 Location: summertown
Ive had 2 7950's and a 7990 do the same thing, except I actually had a hole in the side of one of the 7950's. Its plastic, its gonna break. Just depends on the drop or in my case frontal impact. Sent from my SAMSUNG-SGH-I747 using Tapatalk 2 |
11-29-2012, 10:24 AM | #7 |
Spent time reviewing other servo brands before choosing Hitec, Felt covered by the assurance of year warranty, strong metal gears, reasonable torque running at 6 volts 333oz, can handle 7.4 volts, I just did not know or hear that cases are not covered, it is not the money.
11-29-2012, 10:29 AM | #8 |
| Re: Hitec Servo Caps FYI |
11-29-2012, 10:39 AM | #9 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
I have sent in Servos with broken tabs and they replaced them. I am sure they are more worried about someone opening the servo up themselves. On a side note I tumbled my 8 pound super off of a cliff down about 40 feet. Broke 4 revo ends, 2 links, bent lots of screws but the servos all held up fine. I would not not write off hitec over this. I have broken JR cases from just tightening screws.
11-29-2012, 10:46 AM | #10 |
They give you rubber groments for a reason...
11-29-2012, 12:20 PM | #11 |
These are servo clamps. If you did not know. |
11-29-2012, 12:24 PM | #12 | |
| Re: Hitec Servo Caps FYI Quote:
11-29-2012, 12:38 PM | #13 |
| Re: Hitec Servo Caps FYI Good advice. Thanks. Last edited by douglastee; 11-29-2012 at 12:39 PM. Reason: typo |
Hitec Servo Caps FYI - Similar Threads | ||||
FYI on upgrading to DIGITAL servo and stock RTR AX10 radio system! | goodoldlevi | Newbie General | 7 | 04-15-2013 08:59 AM |
Hitec APP-21 servo tester work with Hobbico CS170 servo? | neuro242 | Electronics | 11 | 09-24-2009 12:47 PM |
HiTec HS645MG Servo & 3Racing MRC2408 Servo Mount | stomper4x4.com | Losi Mini-Rock Crawler | 1 | 05-10-2009 06:33 PM |
Hitec Servo Voltage Ratings.......the answers from Hitec | roktoy | Electronics | 12 | 08-25-2008 06:07 PM |
