Thread: Motor question
Old 12-01-2012, 09:52 AM   #1
Default Motor question
I have a Traxxas 550 12t motor that needs new brushes.
This morning I saw a motor can, and I put 2 and 2 together.
Is it possible to put a motor "core" and put it into a rebuildable motor can?
Thanks
mitchr97 is offline   Reply With Quote
Old 12-01-2012, 10:47 AM   #2
Default Re: Motor question
Thanks
Yes, it is possible to take the armature ("core") and put it inside a rebuildable can. But in your situation it will not work, the traxxas motor is a 550 size and almost all rebuildable motors are a 540 size, so it is too big. Also the traxxas armature has fans on it to help cool it down, and those will not fit in a 540 can.
ax-10 crazy is offline   Reply With Quote
Old 12-01-2012, 01:39 PM   #3
Oh.
Old 12-01-2012, 04:27 PM   #4
Couldn't I pull the fan off, shorten the shaft, and drill the magnets to be wider on the can?
Old 12-01-2012, 04:30 PM   #5
Not sure what you mean by drill the magnets, but because the 12t is a 550 it may have a longer armature. You could always take it apart to find out, no harm if it is already broke.
Old 12-01-2012, 04:37 PM   #6
Cool, thanks
Old 12-01-2012, 07:59 PM   #7
Ok. Here is what I did.
I took the axial 27t motor can:
The traxxas 12t armature:
12t to 27t:
2+2=
I don't have my rebuildable can with my cuz' it's in my kyosho, and my dad took it... I don't know what he is doing... but i have a feeling it has something to do with my birthday tomorrow...
Old 12-01-2012, 09:13 PM   #8
It looks like it is a little too long I didn't realize the armatures in the 12t traxxas motors are that long.
Old 12-01-2012, 09:30 PM   #9
I didn't either...
We will see.
Maybe i could run longer screws, with spacers, and maybe some lexan with vents around that or something.
Old 12-01-2012, 10:26 PM   #10
I didn't either...
We will see.
You still need something to securely hold the bushing at the top. Maybe it is time for a new motor They don't last forever, if they did jrh and brood would be out of business
Old 12-02-2012, 09:11 AM   #11
I have one, it was just an expirement. Thanks for all of the help
Old 12-02-2012, 11:53 AM   #12
You won't have the correct magnet coverage. What you are trying will not work....
Later EddieO
EddieO is offline   Reply With Quote
Motor question - Similar Threads
20t motor and 45t motor gearing question? rcstrike Newbie General 1 11-16-2011 03:40 PM
motor question? masterofdeth Losi Micro-Rock Crawler 3 01-29-2010 01:46 PM
mm motor question eric113 Electronics 1 01-07-2006 01:26 PM
motor question` mistabigshow Electronics 2 02-28-2005 04:32 PM
