12-10-2012, 06:42 PM | #1 |
Rock Crawler Join Date: Aug 2010 Location: Surrey BC
| Tekin RS PRO Problem
Hey guys I have a buddy of mine that runs a RS Pro in his trail truck. We just put it in and are trying to calibrate it for proper use. Now we have done the calibrating many times and seems to cycle throught the process quite easily but the problem is that it has faster speed in reverse then in forward. We have calibrated it in th eradio normal possition and even in the reverse setting of the radio but still come up with the same problem. Is there something we are missing guys mayeb some of you have had the same problem and if so could you jump in and let us know what to look for or fix. Thanks in advance guys. |
12-10-2012, 08:04 PM | #2 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
| Re: Tekin RS PRO Problem
Do you have a hotwire? If so, change the motor direction in the ESC.
12-10-2012, 08:12 PM | #3 |
Yeah I have the Hotwire just haven't taken it over there and hooked it up. That does make sense though. I thought maybe it was something else, but I will definitely work on that idea in the next few days. Thanks for your help bud will let you know what happens. |
12-11-2012, 04:40 AM | #4 |
If it's a brushed motor, you have reverse timing, so it runs faster in the direction that is "advanced" for the motor. So, what motor are you running? [Actually, brushed/brushless, sounds like timing is involved] |
12-11-2012, 06:08 AM | #5 |
13.5 brushless of some sort ....thhinkin redline
12-11-2012, 08:46 AM | #6 |
| Re: Tekin RS PRO Problem |
12-11-2012, 02:58 PM | #7 |
ok thanks guys will do on the weekend ....thanks for the info
Tekin RS PRO Problem - Similar Threads | ||||
pls help me choose. Tekin rs pro or mamba max pro? | painter4x4 | Axial Wraith | 9 | 01-14-2012 09:48 AM |
Problem with Tekin RS system in my LCC, will a BEC fix my problem? | rcboy514 | Electronics | 3 | 01-12-2012 05:55 PM |
Tekin Problem or Radio Problem? | Harvo | Electronics | 8 | 07-30-2010 06:02 AM |
