12-30-2012, 02:48 PM | #1 |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
| Chassis as the ground???
Does anyone see any problems if I were to use the chassis rail (scx10) as the ground? I have two leds I want to install at the back of my truck but I am not keen on having a bunch of wire going from the front to the back as the chassis is stretched. This way all I will have to do is run one wire (positive) to the back. Any thoughts on this? Have you done it before? Thanks |
12-30-2012, 03:03 PM | #2 |
| Re: Chassis as the ground???
I've never done it in an RC. Yes, it's the "typical" method in 1:1's. Would it work? Yes. Should you do it? Could be. Just make sure no other wires (that are "hot") hit the chassis. This includes motor wires. I would "prefer" to use wires for a ground/return line, NOT the chassis. |
12-30-2012, 03:11 PM | #3 | |
| Re: Chassis as the ground??? Quote:
Thanks | |
Chassis as the ground??? - Similar Threads | ||||
ground vs air | bigshafty | Newbie General | 5 | 10-30-2008 12:48 PM |
From the ground up. | aubie | Tamiya Txt-1 and Juggernaut | 34 | 09-22-2005 08:48 PM |
