01-07-2013, 08:34 PM | #1 |
Quarry Creeper Join Date: Dec 2012 Location: Spokane Valley
| How do you keep your electronics cool?
As it states how do you keep your electronics cool, or what's the best way to keep them cool. Specifically esc and motor(s). I'm running a moa super with a 3s lipo and my motors and esc get hotter than I'd like them to. Motors and esc are stock exceed stuff (stoc esc and 540 60t motors), but it's what I can afford right now. So do the motor heat sinks work? If so how well. And or the esc, it has a heat sink already on it and it still gets hot. Are there any universal esc fans out there? |
01-07-2013, 08:37 PM | #2 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
| Re: How do you keep your electronics cool?
Try and regear the motor's , and they do make esc cooling fans.
01-07-2013, 08:54 PM | #3 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
As old man said... regear. heat sinks on the motor should work OK. Hobbypartz sells some fans for cheap. exceed sucks. When they blow up, get a side winder, or a holmes brxl. |
01-07-2013, 08:59 PM | #4 |
Alright I'll take it to a LHS tomorrow and see what they have for pinion gears and fans. The original plan was to go brxl but funds aren't allowing that right now. So I'm getting everything separate (bec and lipo cutoff) so I want to get an esc that doesn't have everything built in eventually. |
01-07-2013, 09:02 PM | #5 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
Like John Holmes says, "Volt up, gear down"
01-08-2013, 12:34 PM | #6 |
I don't know about gearing down, I'm running a 12t pinion gear right now and I already get lots of clodstall. If anything I was hoping to be able to get a higher toothed pinion gear. Might just have to get better motors.
01-08-2013, 03:58 PM | #7 |
Newbie Join Date: Aug 2012 Location: saline
A fan/heat sync maybe
01-08-2013, 04:10 PM | #8 |
I figured out what I'm going to do. My motors at 60t with a 12t pinion gear, I'm going to get some 35-40t motors with probably 20t pinion to keep them cool.
01-08-2013, 06:29 PM | #9 | |
| Re: How do you keep your electronics cool? Quote:
Not the combination I would have suggested if the ESC & motor are already running hot. | |
01-08-2013, 06:39 PM | #10 |
If I put an 11t or 10t on my current motor I'll have so much clodstall I won't be able to climb anything. The thought being with the lower turn motor and higher tooth pinion is the motor won't be spinning as fast to go the same speed. Therefore the motor will stay cooler. I think the 60t just doesn't like the volts of the 3s lipo. I'll also put a fan on the esc, eventually I'll get a different esc all together. |
01-08-2013, 08:51 PM | #11 |
Never mind, I was thinking backwards. Do you guys think if I put in an 11t or 10t pinion gear it'll be better and I'll have less clodstall? |
How do you keep your electronics cool? - Similar Threads | ||||
lowering the body and the electronics getting the electronics in a waterproof box | m1009cucv | Axial SCX-10 | 15 | 10-01-2011 07:45 PM |
Cool little water-tight electronics boxes... | JavelinSST390 | General Crawlers | 3 | 09-14-2008 06:53 AM |
This site has some cool RCs and other cool stuff | Gula | Non Crawler RC's | 2 | 09-07-2008 09:09 AM |
Now this is Cool!!! | nandez11 | Chit Chat | 7 | 05-24-2006 10:23 PM |
this is cool. | BUBBA069 | Chit Chat | 14 | 06-01-2005 06:34 PM |
