01-07-2013, 09:53 PM | #1 |
Newbie Join Date: Oct 2012 Location: Detroit
| Need help with an esc
I have a Novak brushless 17.5 turn motor. Want to use it for crawling. The esc that I have is a Sphere esc. Pretty good. Just want something that I can program a drag brake. Also would like to run an 11.1 3s lipo. Any info would be great. Thanks
01-07-2013, 11:59 PM | #2 |
Pebble Pounder Join Date: Aug 2012 Location: Finland
| Re: Need help with an esc
Mamba max pro
01-08-2013, 01:39 AM | #3 |
Rock Stacker Join Date: May 2007 Location: Fort Payne
Had sphere requires a dbl tap to reverse. I sent it into factory because it had a dead spot when it started to turn they called and said the no longer had the parts to fix it about six months later I got it back fixed one half a battery pack later it had a dead spot again thanks for fixing but it didn't stay Sphere I had didn't have any type Of lipo cutoff and I never tried the drag If you want the best advice then look at the MMP. |
Need help with an esc - Similar Threads | ||||
Which ESC Brake/Reverse Type Setting on my Mamba Max ESC? | b00st3d | Venom Creeper | 3 | 01-24-2010 04:34 PM |
older esc anyoen try these LRP RUNNER PLUS ESC W/ REVERSE | rockwerks | Electronics | 9 | 08-16-2006 11:03 PM |
RX pack & ESC, remove the red wire or leave the ESC switch off | BenW | Electronics | 5 | 02-23-2005 06:25 PM |
