03-12-2013, 03:44 PM | #1 |
Newbie Join Date: Nov 2012 Location: Southern Utah
| Dual 55t on AE-2 ESC?
I'm a total noob to RCs, but I am learning. Bare with me. I'm running a Honcho. I've searched the forum for more info about this, but from what I understand, if I want to run Dual motors on the stock AE-2 ESC, I need to run dual 40T motors or higher since the ESC has a min of 19T, correct? From my understanding, running dual motors they get recognized at half by the ESC so a 40T would be recognized at 20T, a 55T would be 27.5T, etc. I already have the Level3 dual motor mount. I was thinking of getting some 55T motors. Can the AE-2 put out enough juice to handle this without burning up? Also, would I want to set them up Parallel or Serial? Link I'm on a budget so I can't fork out the cash for an ESC just yet. I'm hoping I can get the dual setup on the cheap. Since I am new to this I don't want to fork out a lot for nice expensive parts when I will probably end up breaking things. Any help would be much appreciated. Please take it easy on me! |
03-12-2013, 05:34 PM | #2 |
| Re: Dual 55T on AE-2 ESC?
You should be fine with dual 55T's on that ESC. Wire them in parallel. |
03-13-2013, 09:13 AM | #3 |
| Re: Dual 55t on AE-2 ESC?
Thanks for the reply. Much appreciated.
03-13-2013, 09:46 AM | #4 |
Quarry Creeper Join Date: Mar 2013 Location: Plymouth
if you dont mind, i have a question.... why are you wanting to run dual motors? a single 45t of 55t works great in a honcho. your increasing its weight, doubling the torque going through the transmission and cutting your run time.... you have alot higher chance of tearing up your driveshafts and tranny gears with the dual motors. your gonna break more stuff with the twin motors.... Im not trying to lecture, only help....
03-13-2013, 10:50 AM | #5 | |
| Re: Dual 55t on AE-2 ESC? Quote:
03-13-2013, 05:37 PM | #6 | |
If you run the rig and the motor is hot, you have binding or are overgeared. My son usually runs a decent 35T single motor on 3S LiPO in his scaler with decent speed and no issues. His wheels are weighted (not home right now, not sure how much weight). He also had a Venom Creeper with a single 35T on 3S with ~7oz in each front wheel.....no issues. To me, a "decent motor" is a Holmes Hobbies or Br00d machinewound motor. | |
03-13-2013, 07:43 PM | #7 | |
03-15-2013, 06:51 AM | #8 | |
Rock Stacker Join Date: Feb 2013 Location: North Texas
03-15-2013, 07:57 AM | #9 |
| Re: Dual 55t on AE-2 ESC? That is very true, but, the gear mesh should be checked first. I've seen way too many guys burn up motors because the mesh was too tight.once mesh was corrected, it ran great. If the msg is correct and the motor is getting too hot, then drop pinion sizeor increase spur size or both.
Dual 55t on AE-2 ESC? - Similar Threads | ||||
Futaba 9CHP setup for dual steering, dual esc | duartev | Electronics | 5 | 06-07-2009 08:58 AM |
Dual 55T??? | ElChupacabra | Traxxas Crawlers | 14 | 03-11-2008 10:34 PM |
Quad Titan or dual Integy 55t? | Smib | Newbie General | 9 | 02-04-2007 08:52 PM |
Dual 55T motors, Novak SR, 14.4 V diagram | 4RnrRick | Electronics | 12 | 12-24-2004 06:54 PM |
