03-20-2013, 07:35 PM | #1 |
Newbie Join Date: Mar 2012 Location: amarillo
| MOA electronics problem
I have a dual sidewinder setup I'm running on a dx3r pro so I'm using a Novak dig switch (and please I don't want to heard how I should get a futaba or something 4 channel so if your gonna say that please don't post) I have had a castle 10a bec and one of two brand new sidewinder micro's that have shorted out and burnt up, yes before and after I give new electronics power I check and double check that all wires are in their proper places, but I have still burnt up a brand new bec and sidewinder micro. Any good advice? Thank you.
03-20-2013, 07:57 PM | #2 |
| Re: MOA electronics problem
Could be a bad bec. A fellow member on here had a problem where the interal wires in the bec touched each other and cooked one of his esc's. How do you have your bec wired up? |
03-23-2013, 06:28 PM | #3 |
I have my bec in the bind plug, servo in servo plug, esc's in channel 2 & auxillary (with red wire pulled out of servo connectors on both esc's) but you have to remember that i am also using a novak dig switch that before and after they burnt up i checked to ensure that the wiring was all correct so i dont know if that could play into this issue as well?? Also do you think that castle will replace them considering that they were purshased 3 days before this happened?
MOA electronics problem - Similar Threads | ||||
MOA electronics | OTHGbronco82 | Electronics | 9 | 11-24-2012 03:20 PM |
moa electronics | cboggs | Team Losi Comp Crawler | 10 | 11-29-2009 10:40 AM |
