Thread: help mamba pro question
Old 03-24-2013, 08:37 AM   #1
Default help mamba pro question
everything is new ....including me to this ,I have a tekin reline 13.5 motor ,and the mamba pro esc and castle bec .....I believe everything is wired correctly,,,, when the sensor harnes is plugged in the motor just shutters and wont spin.....when i unplug the sensor harness it works fine ......HELP !!!!
chevycraft is offline   Reply With Quote
Old 03-24-2013, 08:45 AM   #2
Make sure your motor wires are hooked up correctly, A-A, B-B, C-C
Sent from my GT-I9100 using Tapatalk 2
sidehiller is offline   Reply With Quote
Old 03-24-2013, 09:08 AM   #3
mrG
Default Re: help mamba pro question
Double check that the sensor is plugged in all the way, push it in with a small allen. Have you hooked it up to the castlelink to check your settings?
mrG is offline   Reply With Quote
Old 03-24-2013, 09:40 AM   #4
Thanks guy`s for the help it was the wires on the motor , I didn`t know they had to be matched .....This forum is awesome and so are you guys for helping ....
Old 03-24-2013, 05:40 PM   #5
Check and see if the setting in the Castle program that its on brushless (sensored).
squatch71 is offline   Reply With Quote
help mamba pro question - Similar Threads
Dual Mamba Micro Pro question... maRRtin Electronics 5 03-12-2012 07:34 AM
novak 7.5r with mamba max pro question. obebaldone1 Electronics 2 11-19-2010 08:02 PM
mamba max pro question Boids Electronics 13 04-30-2010 07:48 AM
Mamba Max Pro question wrightcs77 Electronics 4 01-23-2010 10:00 AM
