04-12-2013, 05:42 PM | #1 |
Quarry Creeper Join Date: Sep 2010 Location: In the pre-game lobby
| Weird ass motor issue!!
Alrite rc gurus, i got one for ya! My buddy has a tamiya hilux/axial hybrid. Cool ass rig. Tamiya looks with axial funtionality. Anyway, in searchof more wheelspeed than the rooster/55t integy combo was giving, he pulled the motor, & dropped in a non-labeled 16t sealed can motor. Thing goes like a stabbed rat, for about 5 mins. Here's the weirdass part.After the 5 mins or so, the wire on the posistive terminal of the motor, gets so hot, it melts the solder, & pops right off! The roosteris staying cool throughout. The wires are about average gauge, like ya get with an fxr. He's runnin a 2s lipo.Not sure what C-rate they are. And don't know why mah would matter. They vary. Happens with any of'em. Anyone out there know what's goin on here? I've hada ton of different esc's, & runnem with many different lipo packs, & have never even heard of this! Thanks all.
04-12-2013, 05:53 PM | #2 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Re: Weird ass motor issue!!
If nothings bound up then it could be a gearing issue or the low turns on the motor.
04-12-2013, 06:03 PM | #3 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Did you change the gearing when you swapped in this motor? Later EddieO |
04-12-2013, 06:51 PM | #4 |
No eddie, all the gearing is the same as with the 55t. I've made big motor changes before without anything close to a result like this. I'm dubious about the generic can motor tho. Still, what can a motor have wrong with it that'd cause that?
04-12-2013, 07:52 PM | #5 |
Quarry Creeper Join Date: Mar 2013 Location: Plymouth
Is the motor can itself getting super hot? Even if it has huge wires on it, if the solder joint or motor tab has too much resistance, it can still overheat....
04-12-2013, 08:47 PM | #6 |
Quarry Creeper Join Date: Apr 2012 Location: Missouri
Your geared wrong, way wrong. Melting solder kind of wrong.
04-12-2013, 08:49 PM | #7 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
04-12-2013, 08:55 PM | #8 |
Testament to the Rooster though...
04-12-2013, 09:57 PM | #9 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
Ass motor?!? (Sorry. Couldn't resist.) |
04-12-2013, 10:12 PM | #10 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
You may have a bad connection on the motor wires. With my experience with tamyia connectors, that could be a problem. And i might just be the fact that you are over the esc's motor turn limit.
04-12-2013, 11:52 PM | #11 |
The motor is massively overgeared.....55t gearing to a 16t? I dunno why people think this is ok, to just drop a much faster motor in the truck and hope all will be good. A 16t is no car or truck is going to run the same gearing as a 55t. I can tell you, the motor is getting hot because its overgeared. You probably have shorted it, so now its going to overheat the moment you apply power to it. There was likely nothing wrong with the motor before it was installed. Later EddieO |
04-13-2013, 12:42 PM | #12 | |
RCC Addict Join Date: Mar 2009 Location: Chilton
| Re: Weird ass motor issue!! Quote:
What spur and pinion is he running on it? Just for kicks. I hope you don't say 80t and 20t or even close to that. Last edited by craddock35; 04-13-2013 at 12:44 PM. | |
04-13-2013, 08:52 PM | #13 |
Excellent fellas. makes sense to me. Thanks
04-15-2013, 09:34 AM | #14 |
Newbie Join Date: Mar 2011 Location: Loomis
| Re: Weird ass motor issue!! |
04-15-2013, 10:22 AM | #15 |
Weird ass motor issue!! - Similar Threads | ||||
weird controler issue | puddin | Axial Wraith | 0 | 03-10-2013 11:25 AM |
Weird servo issue | Nimyad | Electronics | 23 | 02-13-2013 10:05 AM |
Weird issue with new HH brxl | LDogg | Electronics | 11 | 09-08-2011 08:02 PM |
weird issue with Dx3e... | R/CMaxximus5.0 | Electronics | 10 | 05-01-2010 06:56 PM |
Weird Quark issue? | RXcrawler | Electronics | 3 | 05-07-2007 11:01 AM |
