04-18-2013, 07:07 PM | #1 |
Pebble Pounder Join Date: Oct 2004 Location: Eastlake,OH
| FlySky Radio help,,takes off when radio if off?
I swapped my stock radio out of my scx10 jeep today for my flysky,so I could use a winch. Everything works fine,but if I shut off the radio it takes off? It doesnt do it when you turn the rx on without the radio. Once it connects to the radio then you shut off the radio,it takes off almost full speed but seems to have a little jerky-ness to it. I dont recall this happening when I used the radio on another,and looked at the settings,nothing appears to be off or anything? The electronics are stock that came in my scx10 rtr,maybe a conflict of something? |
04-18-2013, 07:37 PM | #2 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
Never shut the radio off before the truck and never turn the truck on before the radio. You can do damage to the ESC including burning it up. Sent from my RM-845_nam_vzw_100 using Board Express |
04-18-2013, 08:05 PM | #3 |
Your rig should always be last on, first off.
04-18-2013, 08:09 PM | #4 |
| Re: FlySky Radio help,,takes off when radio if off?
Yea thats usually how I do it anyway,lol and I know people will just say "well dont do it like that then" Im just curious why this is happening? I used this radio on one of my older rc's and no issue,my son uses a flysky on his slash and it doesnt do that,just wondering why now?
04-18-2013, 08:30 PM | #5 |
Irs how the rx responds to the loss of signal Sent from my RM-845_nam_vzw_100 using Board Express |
04-19-2013, 07:55 AM | #6 |
Rock Crawler Join Date: Nov 2010 Location: Ohio
Why does a chicken still run when you cut the head off? Same deal, you cut the control signal off, it will go out of control. Just because others you have, have not, doesn't mean that they wouldn't next time. The run away issue is why you always turn the radio off last.
04-19-2013, 09:19 AM | #7 |
Rock Crawler Join Date: Oct 2006 Location: Fernley
You might have the fail safe turned on. The one for gas, where if it looses signal it's supposed to go to full brake to keep the car from running away. I know you can do it with this radio. I would have to look up how to disengage but it should be in the manual.
04-19-2013, 10:31 AM | #8 |
I looked it up and it does mention a F/S option,I'll look into it,Thanks Rhett314!
04-19-2013, 10:43 AM | #9 |
Moderator Join Date: Jan 2004 Location: chicago
my gt3b does the same thing, where as my futabas and speckies dont. its easy enough to just turn off the rig before the rx, but if i could 'fix' it with the failsafe, it would keep those times where you forget to turn off the truck first a little less exciting. |
04-19-2013, 03:26 PM | #10 | |
| Re: FlySky Radio help,,takes off when radio if off? Quote:
Not sure what a stock or hacked GT3B has, never looked. I was taught, use, and teach, "TX on, RX on.....RX off, TX off". Pretty simple. My son learned that at ~age 5....... | |
04-19-2013, 04:34 PM | #11 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
This is a helpful video. He shows how to bind and set up a failsafe. How To Bind, FlySky FS-GT3B 2.4ghz 3ch Receiver And How to setup fail safe on FS-GT3B Receiver. - YouTube |
04-22-2013, 01:58 PM | #12 |
Quarry Creeper Join Date: Apr 2009 Location: Ottawa, ON, Canada
Turning your gear on and off in the proper order is fine when it's working properly. But sometimes sh!t happens: radio breaks, car/boat goes out of range, your kid experiments with the switches , so the OP has a valid concern and as far as I'm concerned a modern radio should not do this. Hopefully it's just the fail safe and it can be changed to neutral, too bad Flysky doesn't set it to neutral from the factory so it's less likely to cause a problem. |
04-22-2013, 07:44 PM | #13 |
Rock Crawler Join Date: Oct 2012 Location: Casper
I have an 8ch and a 3ch FlySky Rx and both have the fail-safe on. I didn't even know it could be disabled until yesterday.
04-22-2013, 07:44 PM | #14 | |
In our typical use (we use reverse), "neutral" is a safe bet. For Nitro's, "full reverse" is better, thus "full brake". So, you're a radio manufacturer, what do YOU pick as the "standard" programming?? | |
04-22-2013, 07:46 PM | #15 |
| Re: FlySky Radio help,,takes off when radio if off? |
04-26-2013, 01:32 AM | #16 |
Yep,that was it. Just reset the fail safe for neutral and it worked great when radio was off,Thanks!
FlySky Radio help,,takes off when radio if off? - Similar Threads | ||||
Flysky radio question | merlin3287 | Electronics | 27 | 01-30-2013 07:49 PM |
FlySky FS-GT3 / Eurgle 2.4 GHz radio | Huey | Electronics | 42 | 11-30-2010 11:01 PM |
